Roadster XM Radio install
Old May 24, 2005 | 06:16 PM
paulh's Avatar
paulh
Default Roadster XM Radio install
Just received my 350Z Roadster with the Bose system. Undertand that there is no XM option for the roadster. Does anyone know if the Bose system has an AUX port on the back of the unit? I do not want to install XM with FM Modulation unit because I might as well listen to the radio. Thx.
Old May 25, 2005 | 05:56 AM
ZBoater's Avatar
ZBoater
No, Bose has no aux-in ports. However, check this out and see if it will work for you
http://www.pac-audio.com/products/aai.htm
Old May 25, 2005 | 08:39 AM
nissan350zfan's Avatar
nissan350zfan
I have installed a Nissan OEM sirius Sat receiver in my roadster using the Sat input on the Bose Head unit - if it has a "Radio" button it is Sat capable. See my posts in this thread:
https://my350z.com/forum/showthread....&highlight=SAT
(and ignore the disinformation from Topdown-z).
If you go the non OEM route, then the PAC adapter may be the route to go. Although I don't have direct knowledge that it will work. Do a search to see the other threads that discuss this.
Cheers.
Old May 25, 2005 | 10:28 AM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
The PAC works perfectly in my Roadster and will work in yours as long as the HU has the "RADIO" button. I use one input for my XM MyFi and one for the PC I'm in the process of installing.
Old May 25, 2005 | 11:18 AM
ZBoater's Avatar
ZBoater
The PAC Audio worked great on my 04 Roadster. Here are some pics of the install:
http://www.quiros.net/350z/sirius.htm
Old Dec 7, 2010 | 09:58 AM
BHODGE's Avatar
BHODGE
Default 6.8 Nav Disc
Anyone have a 6.8 Nav disc they would like to sell. Understand there are two disc, one for undating and one for navigation. Thanks
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
