Where can I get new Wind Deflector and LED Lighting system?
Old Nov 14, 2005 | 10:42 AM
BamBam's Avatar
BamBam
Question Where can I get new Wind Deflector and LED Lighting system?
Anyone know where you can get that wind Deflector glass (between the headrests) with the larger Z emblem etched in it?
I have seen this with the leds inside of it and when lit up this looks awesome. I would love to get that setup if anyone knows where I can get it...
Thanks in advanced.
Old Nov 15, 2005 | 09:09 AM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
Bambam,
You're looking for something like this? http://www.rippedzone.no-ip.org/exte...ifications.asp
I got my LED system from www.Hi-tecdesigns.com. Cost about $50.00
The Windscreen and Z logo were custom. The Glass needs to be "CLEAR" tempered(better for LED illumination). The original windscreen has just enough tint to not allow proper illumination. Cost was about $80.00 to have it cut to size.
The Z logo I etched myself using an sand etching kit I picked up at a local crafts store for about $50.00.
A couple of things to note:
If you're gonna attempt this yourself make sure you get an extra set of roll bar covers. The tabs tend to break once removed.
Mounting of the LEDS is critical to get proper illumination. SUGGESTION-- play with with till you 're happy with the look before you permanently mount them.
(Can't find my original posts right now)
Shoot me a PM if you need anymore help with question, installation or wiring
Old Nov 15, 2005 | 10:10 AM
BamBam's Avatar
BamBam
RJ,
Thanks man. That is exactly what I was looking for. I have Hi-Tech Designs up and they suggest 2 of their lights. I will see what I can do about finding the custom glass around Dulles Airport where I live.
Thanks for the advice. I will hit you up for advice when I get all the parts together.
Thanks again man.
Old Nov 15, 2005 | 10:33 AM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
No problem.
When you order form Hi-tech make sure you order the windscreen kit
http://www.hi-tecdesigns.com/store/a...=Interior_LEDs
Lower right corner. It comes with 2 LED's on the strip and is more than enough I think.
I also have an Autocad file (which I can convert for you if necessary) with the Logo I used that I can send you if you need to make the template for the glass.
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
