Slight Ringing Noise
Old Aug 17, 2006 | 02:58 PM
malcolmsmith's Avatar
malcolmsmith
Smile Slight Ringing Noise
I have a new 2005 350Z Roadster with 6,000 miles. Recently, I'vebeen hearing a slight pinging noise from the right side of the car when I slightly accelerate. It almost sounds like coins rattling. I can tap the gas pedal over and over and each time the ringing noise will sound especially in closed in areas like a parking garage. Anyone with information as to what it could be, please give me your feedback. THANKS!!
Old Aug 17, 2006 | 03:29 PM
Built2shredZ's Avatar
Built2shredZ
Might be the dreaded Axle Clicking, there is a TSB on it and its covered by warranty
Old Aug 18, 2006 | 07:20 AM
htlui's Avatar
htlui
Default me too
I have same issue too. Is anyone have same experience and know which part have to fix? Thanks
Old Aug 18, 2006 | 08:47 AM
Built2shredZ
This should help you... Even tho it says its only for 2003-2004 models I would still have them look into it.
Attached Thumbnails Slight Ringing Noise-axle.gif   Slight Ringing Noise-axle2.gif
Old Aug 19, 2006 | 07:32 PM
OZ_350z's Avatar
OZ_350z
I had a similar problem. Nissan diagnosed it and replaced the fuel dampener. The dealer couldnt hear it initially but later admitted they could. The noise I had sounded like a very rapid but very faint drum beat as I tapped the acccelerator. Similar to what you are describing, you could only hear it in quiet places and only at low revs. I couldn't hear any noise when the car was cold but could defintely hear it when it warmed up. The noise also got slightly louder as the weeks went by. All fixed now though which is good. Good luck pal.
Old Aug 21, 2006 | 10:48 AM
malcolmsmith
Thanks for the replies. It's definitely not a clicking noise. It's more like a ringing sound. I will let the dealer know about the fuel dampener. The service guy at the dealership told me over the phone that it sounds like a loose exhaust cover just under the car. Said it could have been scraped underneath lightly and loosened up.
Old Aug 21, 2006 | 11:58 AM
dubbzdiggler's Avatar
dubbzdiggler
I have a clicking sound coming from the rear end, I think the transmission...it's very annoying.
Old Aug 23, 2006 | 07:00 AM
htlui's Avatar
htlui
Hello everyone, I bring my car to the dealer yesterday and confirmed the sound was coming from rear axle. they fixed under warranty.
Old Aug 23, 2006 | 04:49 PM
350convert's Avatar
350convert
I just got an '04 ZR and I hear it in the passenger side rear axle? It sounds like There are coins inside the tire. I will see if the dealer will do anything for me!?
Old Sep 5, 2006 | 12:32 PM
Gavkiwi's Avatar
Gavkiwi
hmmm, my Z is doing this also, I noticed it about 3-4 days ago, only happens really in first, and a little bit in 2nd gear.
Its quite noticeable in first gear, its like a very light squealing sound. I swear its coming from the passenger side, sounds like its coming from the rear axle.
Its barely noticeable with the windows up, but with it getting cooler here I'm enjoying the low humidity and like to have the windows down when leaving work, thats when I hear it the most, I guess i'll get the dealer to check it out when I get it serviced.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
