'06 Roadster - 3500 miles - brakes squealing BAD
Old Sep 29, 2006 | 11:04 AM
banker69's Avatar
banker69
Default '06 Roadster - 3500 miles - brakes squealing BAD
I have the Brembo brakes and they're squealing like HELL. it's only when i'm going under 5-10 mph. I thought it may be brake dust, rinsed that out...wasn't the case. Does anyone have ANY idea what this could be? I don't know jack about brakes, but I do know that they shouldn't be worn down after only 3500 miles!
Old Sep 29, 2006 | 11:38 AM
ANXIOUZ's Avatar
ANXIOUZ
That is a bit soon. Is it all of them or just 1 or 2? My right-rear needs to be checked but I have 23k miles on those pads.
With that few miles it might be worth having the dealer take a look.
Old Sep 29, 2006 | 11:39 AM
banker69's Avatar
banker69
It sounds like it's one of the front brakes. if i had to guess i'd say the front left, but i could very well be wrong.
Old Sep 29, 2006 | 03:44 PM
DCroz's Avatar
DCroz
I too, had a NASTY squeal when using light braking action. I thought it was coming from the front. Took it to a brake shop and it was actually some hot spots on the rear rotors. Got the rotors turned, and the squeal is gone.
Old Oct 1, 2006 | 07:24 AM
firulice's Avatar
firulice
Have you ever locked up hard on your brakes? This can warp he rotors and in that case you can try to get them rotated. If not...go get a can of brake cleaner from your auto parts store for a buck and spray on all of the rotors as you move the car. Many times the sqwealing is because of dirt and dust. The Z breaks will always sqweak a little but should not be excessive or acome from one wheel specifically.
Old Oct 10, 2006 | 10:32 PM
seoulcity's Avatar
seoulcity
i have about 16k on my car.. had my first brake change when i had 5-6000 miles.. lol.. and again at around 13k miles.... dealer said its because of dust and its a "sports car" i was like -_- ok... bastards.. on my 2nd brake change, i changed to slotted rotors n brake pads....
07ZEKE
Aug 23, 2021 09:15 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
