Can't hear turn signal!
Old Oct 20, 2006 | 05:41 PM
zoe's Avatar
zoe
Default Can't hear turn signal!
I drive with the top down all the time. And occasionally I'll make one of those turns at a corner that doesn't bend 90 degrees. And sometimes I CAN'T HEAR THE SIGNAL relay clicking! So, you know, I'm driving down the road oblivious to my infinite turn -- It's embarrasing! Any ideas for me?
Old Oct 20, 2006 | 07:38 PM
Built2shredZ's Avatar
Built2shredZ
Get in the habbit of glancing down after you get done going thru a curve to make sure you blinker went off...
Old Oct 20, 2006 | 08:43 PM
zoe's Avatar
zoe
Wink
That is a very insightful suggestion Built2shredZ. I forgot however to mention that while having the top down, it is also often impossible to see the indicators during the day (I live in AZ where the sun is always shining very intensely )
So, is there any way to easily add some kind of audible enhancement? Is there such a thing?
Old Oct 20, 2006 | 09:53 PM
Built2shredZ
Always glad to help
No modification I know of...
Old Oct 20, 2006 | 10:02 PM
zand02max's Avatar
zand02max
been there done that! Hate the feeling as well!
Old Oct 21, 2006 | 06:43 AM
maxpowers's Avatar
maxpowers
My turn signal clicker does the same thing (it will actually stop making the click noise). After you restart the car it usually returns to normal.
Old Oct 21, 2006 | 07:15 AM
Monsta's Avatar
Monsta
I indicate before I turn and usually intentally cut it off when my hand pass the (stalk, lever, whatever its called) while I am turning.
Old Oct 21, 2006 | 12:48 PM
YBLegal's Avatar
YBLegal
great advise~
Old Oct 22, 2006 | 02:36 AM
zoe's Avatar
zoe
You're kidding of course! I mean, if cancelling the signal manually every time were any kind of solution, I might as well just get into the habit of using hand signals! (my goal is to enhance the technology already there, rather than give in to its shortcomings). Any actual ideas?
Old Oct 22, 2006 | 04:00 AM
imjdoggie's Avatar
imjdoggie
This must be a common problem with our cars because every once in awhile my blinker sound goes out too.
Old Oct 22, 2006 | 05:07 AM
Monsta's Avatar
Monsta
I checked mine and it turns off within a 1/4 turn. And I don't think that its an actual flasher making the noise.
Buy a nice set of white gloves.
Old Oct 22, 2006 | 05:17 AM
Combat350z's Avatar
Combat350z
I have the same problem. I'll be driving and just realize "oh **** my blinkers been on for thel last few exits"
Old Oct 22, 2006 | 05:26 AM
Monsta's Avatar
Monsta
Originally Posted by E***zzzzy
Trust me ---The Flasher is what makes the noise, Unless they have changed what has been working fine for 30 years
Set your turn signal to make a left or right turn. Turn on the key but do not start the engine. You hear the initial beep. After the beep you hear the “flasher”. So why does the “flasher” flicker silent when the beep is on?
I recommend you take it in if the technology is not working in your car. Maybe it’s a faulty signal stalk because mine cuts off with no problems.
Old Oct 22, 2006 | 05:44 AM
y_b_lamron's Avatar
y_b_lamron
I usually have my music up too loud to hear it anyway. I just got in the habit of glancing down. It's an easy habit to get into and takes hardly any time at all.
Old Oct 22, 2006 | 08:09 AM
zoe's Avatar
zoe
Glancing down works for me at night -- but it in the day (here in Arizona) I can usually not see the indicators flashing (sun is way too bright with the top down).
However, I think I may have found a solution! I hope I can find one of these that will fit the Z:
http://www.cartalk.com/content/colum...98/May/01.html
Old Oct 22, 2006 | 09:22 AM
maxpowers's Avatar
maxpowers
The Z doesn't use a traditional relay like a normal car. The click is actually produced by a small speaker.
Old Oct 22, 2006 | 09:37 AM
Eazzy's Avatar
Eazzy
I noticed that when I went to the wiring schematic---Guess have to up grade to a amp and JL Audio
Old Oct 22, 2006 | 09:58 AM
saberphx's Avatar
saberphx
Wire in a 12v 95db backup alarm. You wont ever forget again.
Old Oct 22, 2006 | 01:37 PM
zoe's Avatar
zoe
Thanks - that's a great clue.
Old Oct 22, 2006 | 01:38 PM
zoe's Avatar
zoe
Now we're getting somewhere! LOL!
And I'm serious: Can anyone give me an idea where this thing is located? I want to amplify it...
