ZR - Hot smell after driving
My 06 ZR seems to have developed a hot smell after driving it for only 5 - 10 miles. I don't notice it in the car, only when I stop and get out. The temp guage is normal, all fluids are normal and everything else seems normal. I can't locate the source of the smell. The smell, seems to be rubber or tar based, but that's just a guess. It's no more noticeable with the hood open.
Amy ideas or areas to check? Nothing has changed except I put winter tires on it. Same wheels, same size tires. The tires do not feel warm to the touch.
Thanks everyone
Thanks everyone
My 05ZR did the same thing. The dealer said I had a defective Crankshaft pulley. Also Said if when replaced the belt doesn't tighten up right then I may need a new engine. Luckily this wasn't the case but then again they would have been giving me a new car considering I had just bought it. Strangely enough my pulley was almost cracked in two but somehow or another it stayed in there. He said i was luck it didn't just come apart and ruin the car as I was driving. They ordered a replacement part and put me in a Dodge Charger for about 4 days. Everything has been fine since the repair.
Also you may want to make sure you have no small oil leaks. A friend of mine had a leak due to a faulty Key Seal in his Z. His car would smoke like a chimney after driving it a few minutes but it never ran hot – no check engine light or anything.
Off to the dealership you go... hope they get your straight!
***I thought mine was rubber or tar also but turns out it wasn't lol***
Good news: The dealer couldn't find anything wrong. They blamed it on being new. Interesting though, we can't smell anything anymore either. Maybe there was some plastic on the underbelly somewhere.
350Z_Al
Oct 29, 2020 07:44 PM
