seat moving forward while convertible top being put up
Old May 29, 2007 | 07:30 PM
miller's Avatar
miller
Default seat moving forward while convertible top being put up
i was wondering why the passenger seat tilts forward when the convertible top is being put up and why the drivers seat does not move as well
Old May 29, 2007 | 07:39 PM
scottyslug's Avatar
scottyslug
Well the way i see it i've had many friends in the pss when the top was being put up. It moves forward because I think the pass goes back further and the bar hits or will hit them in the head it happened to friend of my he leaned back and the bar hit his head. So that why its goes forward. saftey feature.
Old May 29, 2007 | 07:41 PM
DBTRACK's Avatar
DBTRACK
no...... it goes forward to access your glovebox for loose items that may blow away with the top down
Old May 29, 2007 | 07:44 PM
iStan's Avatar
iStan
ZR
Huh? Shouldn't it go even further back to make it harder for things to blow away?
Old May 29, 2007 | 07:46 PM
DBTRACK's Avatar
DBTRACK
the seat tilts forward...... so you can put any items in the car in the glovebox that is BEHIND the seat.
Old May 29, 2007 | 08:49 PM
iStan's Avatar
iStan
ZR
Oh ok.
Old May 30, 2007 | 04:24 AM
JMT's Avatar
JMT
The owners manual says that it is a safety measure. An "alert," if you will, to the passenger that tells them the top is in motion. Obviously the driver does not need an "alert" as they are the one that is operating it. You can cancel the seat movement simply by turning off the passenger automatic seatback button on the back.
Old May 30, 2007 | 04:58 AM
350Zenophile's Avatar
350Zenophile
^owner's manual ftw
Old May 30, 2007 | 05:11 AM
ohw's Avatar
ohw
Depends on the length of your arms, as the driver, you lean forward to push the button to lower the top. You shd end up about the same position as the passenger with the seat tilted forward.
Old May 30, 2007 | 05:25 AM
r0mey's Avatar
r0mey
this question has been asked 100 times i just thought it was common sense why it does that
Old May 30, 2007 | 07:13 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Ding ding ding ... Correct
Old May 30, 2007 | 07:17 AM
iStan's Avatar
iStan
ZR
Yay, common sense still hasn't done me wrong.
Old May 30, 2007 | 08:47 AM
KombatKing's Avatar
KombatKing
I thought it moved forward to prevent cervical spine injuries in the event of a rear collision during automatic top operation...
~KK
Old May 30, 2007 | 03:39 PM
Built2shredZ's Avatar
Built2shredZ
The passenger seat tilts forward so you don't whack your passenger in the head with the top... The driver seat doesn't need to do this as you lean forward anyways to hold the button down to put the top down/up...
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Depravity
Oct 1, 2015 04:49 PM
