Z Convertible Question
Old May 24, 2003 | 04:21 PM
Ricky's Avatar
Ricky
Default Z Convertible Question
Just out of curiousity, does the convertible do the 0-60 in 5.4 and quarter mile in about 14.0-14.1 also?
Old May 24, 2003 | 04:50 PM
ares's Avatar
ares
Veteran
only difference being weight, which we dont know, one could only assume very close, convertables typicly add a little weight, maybe 50lbs or so, but the Z doesnt have to try too hard for those times, so yeah... depends if your talkin average, or absolute best?
bigger difference would likely be in handling ability, again, depending how much stability is lost, supposedly the roof on the coups has no structural support, hence the rear strut bar, so the convertable wouldnt lose any strength. only time will tell, and more likely only an expert driver would ever put the car to the limit that it would be measurable.
Old May 24, 2003 | 06:13 PM
350zroadster's Avatar
350zroadster
Auto mag says there is an increase of 100lbs.
Also the weight increase would move the weight distribution from 53/47 closer to 50/50
Old May 24, 2003 | 08:43 PM
ares's Avatar
ares
Veteran
yeah, but adding weight to the rear is never the ideal method of evening the weight distrobution.
nice that it works out that way, but its not exactly a benifit, I could toss 50lbs in my trunk too and call it balance... owell, just my 2 cents.
100lbs sounds like a fair ballpark, you could just look at conv vs coupe mustangs, similair setup, power soft top with glass window vs hard top.
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
