Roof closing problem
Old Oct 28, 2007 | 01:27 PM
tannee's Avatar
tannee
Default Roof closing problem
Hi guys,
I drive a 03 roadster. Ive recently encountered the following problem.
Open the roof, the roof tucks in, the compartment shuts but leaves a little gap as though there's not enough space, and the converible light remains on. I Open the roof again, (only the compartment part comes up), stop and press close roof again. The roof tucks in a bit more then the compartment closes shut. What's going on? I cleaned out the enclosure and tried to make more space thinking that the roof doesnt fit properly because of some restriction and nothing...
Any ideas?
Old Oct 28, 2007 | 08:29 PM
j_z2006's Avatar
j_z2006
i had this experience before but its gone now for no reason, thats pretty embarrass when u try to top down while u are waiting for the light but it got stuck. i suggest u to check with the dealer.
Old Nov 15, 2007 | 11:52 PM
jimmy B's Avatar
jimmy B
yep, that would be embarrasing.
Old Nov 16, 2007 | 10:47 PM
Mang's Avatar
Mang
Look to the other item on the forum regading TOP opening problems, lubrication is in 99% the answer of your problem. Its seems that the first problems start with the electric top operation on early Roadsters (2003 - 2004) now. Soon more will follow !
The electric operation is performed by tiny electric motors (original wiper motors), if there is too much restistance on the mechanical parts (dry gears or bow supports and regulators ) the system will not close at the first attemp but after repeated operations. Soon after one of the motors will fail because of overload, don't wait till that will happen ! Silly US 1800 for one motor.
Lubrication with window gear grease (High pressure and high viscosity) on the gears is necessary, but no dealer will do this at periodical maintanance check.
Give me feedback
Regards frm Amsterdam,
Old Nov 16, 2007 | 10:51 PM
jimmyloose's Avatar
jimmyloose
clear the squirrels out. Should go straight down.
(Mang actually nailed it in seriousness though..)
Old Nov 17, 2007 | 01:04 PM
maxpowers's Avatar
maxpowers
I'm confused....didn't the ZR start production in '04?
Old Nov 25, 2007 | 10:07 PM
crazygideon's Avatar
crazygideon
I think in the rest of the world, they sell models as the year it was made.
Old Nov 27, 2007 | 02:45 PM
KombatKing's Avatar
KombatKing
Roadster started as an '04 model - you could buy it in 2003 though - anyway - make sure you lubricate all the moving parts associated with your roof's opening and closing mechanism - with a good heavy duty silicone based lubricant.
~KK
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
