Treatment for the soft top???
Old May 11, 2008 | 08:16 PM
chicagokid's Avatar
chicagokid
Default Treatment for the soft top???
I didn't see topics regd this. Do you guys use any type of soft top treatment (conditioners, water proof, spray, etc.)??
Or adding some kind of insulation material on the inside of the soft top?
Old May 12, 2008 | 04:54 AM
bluespecv03's Avatar
bluespecv03
Im sure there are plenty of topics. Alot of people are using 303 Aerospace Protectant. It comes in a spray bottle. Found it here locally at a boat shop.
http://www.303products.com/
Old May 12, 2008 | 05:01 AM
For water repelling Scotch Guard is a good product. If your car sits in the sun, as bluespecv03 mentioned, go with 303 Aerospace.
Old May 12, 2008 | 08:31 AM
chickenputo's Avatar
chickenputo
+1
Old May 15, 2008 | 06:30 AM
Z33roadster's Avatar
Z33roadster
just called a local boat store. stoppin by later today.
its like 45 for cleaner and conditioner.
let you all know how it goes...
thanks
Old May 17, 2008 | 12:38 AM
maxpowers's Avatar
maxpowers
I pay less than $10 for 303.....its the best. Remember your top is vinyl so don't use anything for cloth.
Old May 17, 2008 | 12:42 AM
Spork's Avatar
Spork
I go to the man store.
Old May 19, 2008 | 08:34 AM
chicagokid's Avatar
chicagokid
Is this what you guys are using? And 2007 tops are vinyl correct?
Old May 19, 2008 | 08:52 AM
ZPHILE's Avatar
ZPHILE
Default Search the site - if possible - much misinfo out there
The top is NOT vinyl. It's a treated cloth. Almost a rubberized cloth.
Old May 19, 2008 | 12:15 PM
bluespecv03
It is definetly vinyl.
http://www.wolfsteins.com/imports.htm
Poly Vinyl Chloride (PVC) to be exact. Use a vinyl cleaner and protectant. 303 works perfectly.
Old May 20, 2008 | 01:53 PM
CyberZeke's Avatar
CyberZeke
remember, the grey tops on the 07-08s are canvas... not vinyl...
Old May 20, 2008 | 02:03 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
STFU ... ^^^^ Do not listen to this ignoramus.
The Roadster's top is made from synthetic material (two posts up - Poly Vinyl Chloride).
Old May 20, 2008 | 03:30 PM
bluespecv03
Really? Can't Nissan stick to one material?
Old May 21, 2008 | 05:19 AM
dutchboy350Z
Finally some go
Please provide evidence, otherwise I call BS
Old May 21, 2008 | 06:28 AM
CyberZeke's Avatar
CyberZeke
Most times people post questions on this site
and they are attacked for not using the search function...
well, I post something and am told to prove it or you consider it bs...
Take a look on the NissanUSA site...
Old May 21, 2008 | 06:36 AM
jmark's Avatar
jmark
303 makes products for both types of tops. I used the cloth cleaner & treatment on my Miata and it worked like a charm. Make sure you know what top you have....
Old May 21, 2008 | 08:21 AM
dutchboy350Z
Finally some go
The 07-08 tops "appear" to look exactly the same as my 05 top except it's a different color. Why would nissan suddenly change the material they are using just because it's a different color? The word canvas, especially in this case, only describes the texture of the top. Believe it or not "synthetic" canvas has been around for a while now.
Until Haartz or any other reputable source says otherwise IT IS STILL VINYL.
Dear Charles,
Thank you, for taking the time to inquire about RAGGTOPP Convertible Top Care products for complete exterior care. RAGGTOPP products have been thoroughly tested and endorsed by The Haartz Corporation (OEM) the world's leading manufactured of convertible topping for virtually every American and European convertible automobile manufactured throughout the world with the exception of the Honda S2000, Mazda Miata (vinyl) and Nissan 350Z. www.haartz.com
Per Doug Harrtz, the Nissan 350Z has an acrylic/vinyl tops and IS NOT Fabric. It looks and feels like fabric and should be protected with RAGGTOPP Vinyl Protectant with UV blockers and NO Silicone. Several owners of vinyl convertible tops have used RAGGTOPP Fabric Protectant on their tops without harming the material. After you spray the top, you must spread/wipe dry with a clean cloth or rag.
You should use RAGGTOPP Vinyl Protectant on your dash and car bra to protect against UV damage. Our products do not contain nasty silicone and you will not get a wet/shinny look on your dash. Please call me at (800) 377-4700 if you have any questions or need additional information.
Rick
Wolfsteins Pro-Series
(800) 377-4700
Old May 21, 2008 | 10:30 AM
ZPHILE's Avatar
ZPHILE
So, Dumb *** Charles/Dumbboy - insulting Z site DICK, (just thought I'd address you as you address others - you know insulting). Does synthetic canvas = Vinyl??? Does a vendors word mean everything when they are trying to sell their product??? The answer - not sure. Unless you can show from a reliable source - say Nissan, you don't know. Nissan consistently calls the top 'CANVAS, CLOTH'. But, it's obvious that it's not just that. I'm waiting for a call back from NNA to find out for sure. In the meanwhile, don't be a DICK and try to have a civil back and forth.
Old May 21, 2008 | 11:05 AM
dutchboy350Z
Finally some go
Of course you're right, a vendor is going to instruct their customers to use the WRONG type of protectant.
I bet they pulled the top's material name Poly Vinyl Chloride right out their magic hat.
By the way, it's "in the meantime". I don't even know why I'm responding to you. You're one of the few dopes left on this site that still thinks our tops are made from cloth.
Old May 21, 2008 | 11:36 AM
maxpowers's Avatar
maxpowers
Yes and yes. 303 costs a hell of a lot less than Raggtopp and I find it works better. The water beads longer (I'm not sure if thats a gauge to how well the product works......but it can't be bad).
