Cuts in top?
Old Jun 13, 2008 | 04:11 AM
sdl13's Avatar
sdl13
Default Cuts in top?
This week I noticed what looks like crease marks in my top just behind each side window. On close inspection these vertical marks look and feel like something is cutting into the top. It appears that if this continues, I'll end up with several slices in the top. As best I can tell, the top is not being pinched between any metal. Has anyone seen this or had a similar problem? The top goes up and down at least twice every day.
thanks,
sdl13
2006 ZR Enthusiast
Old Jun 13, 2008 | 06:06 AM
maxpowers's Avatar
maxpowers
Pics would help. I've never heard of that problem. If your in SJ then it can't be a result of putting it down in cold temps.
Old Jun 13, 2008 | 07:58 AM
Master Shake's Avatar
Master Shake
Separation at the seams is common, especially on the older models (2004, 05), but I've never heard anything like what you described. Are you still under warranty? If so, I would have the dealer check it out.
Old Jun 13, 2008 | 08:36 AM
BlueZ2333's Avatar
BlueZ2333
I have a 2007 that i bought in jan 2008 and i have the same problem on both sides. I'm taking it in next week...will keep you posted.
Old Jun 13, 2008 | 10:07 AM
SuperBlack350z's Avatar
SuperBlack350z
yup, i'm noticing this on my roadster as well,
Old Jun 13, 2008 | 11:25 AM
maxpowers's Avatar
maxpowers
.........the top problem is like an organism and is evolving into a new form for the '06+'s.
Old Jun 13, 2008 | 02:11 PM
GT350Z2006's Avatar
GT350Z2006
I am geting my top replaced on my 06 as it has cut like spots on each side where the top folds. It isn't bad but since it is free I am going to get it replaced. It is already in at the dealer I just have to get it put on. I know the biggest reason for this is if my car is moving the top is down, and when I stop it goes down. I also have 31k miles on it. If you got it use it.
Old Jun 15, 2008 | 10:14 AM
sdl13's Avatar
sdl13
I'll try to post some pics, but I'm not sure that the camera can distinguish between the shades of black. I too will take it into the dealer and we'll see what happens.
Old Jun 16, 2008 | 01:23 PM
NJ350zr's Avatar
NJ350zr
I have the same problem on my 05 roadster. Which only has 15k miles on it and one full summer season of usage.(NJ)
Old Jun 18, 2008 | 05:33 PM
dfresh713's Avatar
dfresh713
Master
Anyone know if top replacement is covered by the warranty by nissan?? I mean the tears at the seam.
Old Jun 19, 2008 | 07:51 AM
Master Shake
Yes, if you still qualify for the standard factory 3yr/36k warranty. If you have an extended warranty of any kind, then it's tough to say.
Old Jun 22, 2008 | 12:33 PM
QUADZILLA's Avatar
QUADZILLA
seam separation is a know problem by Nissan...Had my 05 replaced at 34k covered by warranty....make sure you ask the dealer who is doing the install...my dealer was sending it out to another shop...I made damn sure the place knew what they were doing before letting them send it...
Old Jul 2, 2008 | 07:02 PM
Phreakdout's Avatar
Phreakdout
I had a tiny tear yesterday. I put the top down once and the rip is now 3" long.
Exact same spot, just below and to the side of the window corner.
Old Jul 2, 2008 | 09:25 PM
Phreakdout's Avatar
Phreakdout
BTW: For those in SoCal, this shop specializes in 350Z top repair and or replacement.
http://www.prestigemobileupholstery....le_top_install
Old Jul 13, 2008 | 09:45 PM
sdl13's Avatar
sdl13
A quick update -
When I took the car to the dealer they didn't give me any grief. They got approval from Nissan for a warranty replacement in less than 24 hrs. The top will be replaced this week and I'll let you know how it turns out.
sdl13
06 ZR Enthusiast
Old Jul 13, 2008 | 09:47 PM
Phreakdout's Avatar
Phreakdout
I wish they would cover my 04 w/50K miles.
I will be robbing a bank soon to cover the replacement costs. (Damn previous owner didn't get this done.)
My insurance may get a claim that I was struck by a flying squirrel.
Old Jul 15, 2008 | 06:54 AM
sexi z's Avatar
sexi z
my 05 has these tiny tears too. exact same sopt on each side. It ALSO has the seperation... this makes me sad.
Old Aug 10, 2008 | 02:49 PM
specialized5223's Avatar
specialized5223
thanks,
sdl13
2006 ZR Enthusiast
I have the same problem, 2 slits in a row, they've grown twice their size in the last 2 months. It's symmetrical to the passenger side as well.
Old Aug 15, 2008 | 10:03 PM
sdl13's Avatar
sdl13
I did get a new top from Nissan, the install looks good and correct. However, I can already see the crease lines where I'm certain that I'll get tears again. Seems like a design defect. The warranty doesn't get extended. The new top comes with a 12 mos/12K warranty but I still have 18 mos and 27K on the original 3yr/36K. My guess is I'll get a second new top courtesy of Nissan but by 2011 or 2012 I'll be buying one myself.
sdl13
Old Aug 15, 2008 | 10:09 PM
sdl13's Avatar
sdl13
sdl13
