Do I need to roll fender
Guys,
I am looking at this set:
volks gtv
19x9.5 (+17 offset) up front with 255/35/19
19x10.5 (+24 offset) in back with 275/35/19
I was running sf challeng before with the following spec and didn't have any problem with the tein s tech springs on a roadster. Roadster sits a tad lower than a coupe.
SF Challenge
19x9.5 +28 235/35
19x10.5 +23 275/35
Any rubbing problem?
TIA,
tnt
volks gtv
SF Challenge
19x9.5 +28 235/35
19x10.5 +23 275/35
TIA,
tnt
Looks ok to me, but you may need a baby spacer in the front. Personally, I'd run a MUCH wider tire in the front than that 235 on a 9.5" wheel. That will look very hipari. I'd go at least 255, if not 265 or 275.
I run 19x9 +31 fronts with a 275 and 19x10.5 +33 rear with a 305. Stock suspension minus sway bars. No rubbing.
