Where to buy material to repair softtop
on
Someone a while back mentioned you can buy some material at a craft store that will attach itself to the top to fix any holes or nicks in the top when the said material is heated, anyone know what the material is??
on
Get the iron on patches. They can be found at any craft store in the sewing dept. Cut a piece about a 1/2" larger than the tear. Put a light thin coat of adhesive (Elmers) on the patch to hold it in place. Then use the iron to get the patch to bond. By the way this is from the inside of the car.
This will work and will last quite awhile. If you can still see light coming through the patch--apply a second patch over the first one.
Remember--it's from the inside of the car.
Good Luck.
Good Luck.
08-06-2021 06:19 AM
Justin100
11-29-2015 03:58 PM
