Passenger seat removed, TOP NOLONGER FUNCTIONING!
Old Jul 29, 2023 | 05:35 AM
rtfutrell97's Avatar
rtfutrell97
Originally Posted by Phreakdout
There is a connection between the passenger seat control and the soft top lock switch. Interrupt the soft top lock switch operation and the top's not going to work.
I assume when you removed the seat, the B353 connector was attached to the seat.
(Just a thought) If you could remove the seat control and wire harness from the pass seat leaving everything connected, then perhaps there would still be continuity between the control unit and the switch. Tricking the system to thinking the seat is still there. Strap it all together with plastic zip ties and place it under the aftermarket seat.
Just curious, when you remove the factory seat, does the airbag light come on? I'd think it should.
I tried this i no longer have the seats but i still have the white box connected. The windows will not roll up and i had to manually close the top. Does anyone know if the box is bad or what?
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
