Roadster Install
Old Dec 26, 2008 | 08:12 PM
pfunkmob's Avatar
pfunkmob
Default Roadster Install
Looking for someone that has put a box in the hole for the roadster. Got an 07 and a 10" sub I want to install. I hate free air so I'm looking for ideas.
Old Jan 6, 2009 | 04:46 PM
dsmZ's Avatar
dsmZ
ppl have fiberglassed/dynamatted the cubby...but thats as close as you will probablly get to a BOX
Old Jan 6, 2009 | 07:47 PM
johns350's Avatar
johns350
Default I'm sure there is more info in the audio forum
but here, get this -> http://www.wickedcas.com/product.php...2&cat=0&page=1
It should do the trick...
Good Luck - and let me know how it sounds!
Old Jan 29, 2009 | 11:44 AM
SC350ZR's Avatar
SC350ZR
The problem with just trying to make an enclosure of the space in the cubby behind the seats is that it is way to big for a normal 10" sub, easy 1+ qft. With that big volume the sub will not take much power without issues of failure.
I made two enclosures of MDF/fiberglass in my ZR, but I also made a new panel to go across. I"m not a fan of 100% fiberglass enclosures unless they are really thick and well dampened using dynamat or similar. It will generate a hollow sound if it is just bare fiber glass.
I'm looking into making a drop in enclosure to replace the factory sub but still nothing ready, hopefully later this spring when I have some more time.
It will be 0.6-0.8 qft sealed for a 10" sub firing into the seat and held in place using factory bolts.
Old Jan 30, 2009 | 06:40 AM
kenpo_350Z's Avatar
kenpo_350Z
What about putting a box in the trunk would that cause too much trunk or tonneau rattle? I want to put a sub in the stock spot too.
Old Jan 30, 2009 | 06:43 AM
Netko350Z's Avatar
Netko350Z
OP this is your best option.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
