Any Preference on Brake Fluid??
Old Apr 23, 2009 | 12:14 PM
driver350's Avatar
driver350
Default Any Preference on Brake Fluid??
Hey guy's, I wanted to ask if you have a preference on what type of break fluid to use? I have a can of Preston DOT3 sitting on the shelf for another car. Wasn't sure if I can use the same stuff in my Z.
Thanks.
Old Apr 23, 2009 | 12:40 PM
myork's Avatar
myork
If the can has been opened and has been there longer than 3 months dispose of it - it has already absorbed water and can degrade your braking system.
As far as brake fluid type - as long as you arent racing the car where you run the chance of boiling the fluid, any fresh DOT3 fluid (read: new unopened can) is good for a daily driver. Whatever your preference happens to be should be fine.
That being said, I used Motul brake fluid the last time I flushed my brakes.
Old Apr 23, 2009 | 12:50 PM
*ICE*'s Avatar
*ICE*
SuperBlue Dot 4... best of the best!
Old Apr 23, 2009 | 01:03 PM
driver350's Avatar
driver350
Ok, I'm not sure whats in it though. I will buy fresh stuff, not sure about mixing matching; if it's DOT 3 in it and add DOT 4 though. My level is half full and wanted to top it off.
Just making sure....
Old Apr 23, 2009 | 02:13 PM
myork's Avatar
myork
NO - do not mix DOT3 and DOT4 fluids - they are NOT compatible. If you want to switch to synthetic (DOT4) fluid, you must flush out the DOT3 fluid first.
Old Apr 24, 2009 | 02:23 PM
Xzero's Avatar
Xzero
Im finally getting around to my Brembo conversion and I'm going with ATE SUPERBLUE and when I have to flush it again Im going to use ATE TYP 200. Both are the same thing just a different color so when you bleed the system, you know when all the old fluid is out!
Old Apr 24, 2009 | 02:31 PM
Kwame's Avatar
Kwame
<--- Endless RF-650.
samansharif
Sep 25, 2015 12:31 PM
