Just got 350ZR...any advice
Old May 12, 2009 | 10:21 PM
Papabear1977's Avatar
Papabear1977
Default Just got 350ZR...any advice
Hey all, new owner of a 2005 350ZR. I needed some advice tho. Any help is appreciated.
1) Replacing the bose system. I wanting to replace the whole sound system. I don't need a nav system or anything flashy, just something that would sound good.
2) Car Alarm....what are you using or recommend.
3) Battery....with a new sound and alarm system, would I need to replace the OEM battery with a better one, and if so, what do you recommend.
Thanks ALL
Old May 13, 2009 | 04:57 AM
A3VT 74's Avatar
A3VT 74
On the sound... it depends on how much and how crazy you want to go. As of now I still have the bose... sounds good. But if you want to replace it then I would recomend MB quarts / Boston acoustics / JL Audio
On the alarm.. you have an alarm. The stock alarm is good and your car will not turn on without the key.. not sure if you know but your key has a little chip inside and the car will not turn on without it
On the battery. depending on how crazy you go you can upgrade your battery / add some capacitors or both... but if you are just using a simple set up then your battery should be fine.
Enjoy.
Old May 13, 2009 | 05:40 AM
Phreakdout's Avatar
Phreakdout
Regarding the alarm, the factory is fine but it doesn't have a motion sensor, shock sensor or glass breakage sensor. I would recommend adding an aftermarket alarm.
I'd say you will be fine with the stock until you get some wheels and install the stereo. In stock form, thieves are not so interested. They'd rather steal a Honda or older Camry for the parts.
Old May 13, 2009 | 07:23 AM
xUSAFxxTACPx's Avatar
xUSAFxxTACPx
1) Pioneer head unit, JL Audio Amp/W3 or W6 is a great setup.
2) Stay with the stock alarm, it does its job fine.
3) The stock Optima battery is good, it will put out the power you need. I would recommend getting a some more engine grounds.
Old May 13, 2009 | 08:25 AM
shinobi89's Avatar
shinobi89
I just had the Viper 5901 installed. Love it.
http://www.viper.com/ShopViperProduc...ItemCode=5702V
You can get it cheaper off of Amazon.
Old May 13, 2009 | 03:05 PM
ZR_Yancy's Avatar
ZR_Yancy
An aftermarket alarm w/ microwave motion sensor is great for ZR's. I have it & anytime I have the top down & have run into a convenient store or gas station, I just arm it & I can keep the top down. If any motion happens in the cabin area, it will go off. I also have a 2 way pager & the camera that sends the pic of the intruder to my LCD 2 way pager.
http://www.asianwolf.com/car-alarm-8100rsxmny.html
norrix420
350Z Roadster
May 23, 2022 05:11 PM
liqalu04
Jan 2, 2022 12:58 PM
user 62082028
Southern California
Jul 28, 2017 11:47 AM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
