Vandalism or Normal Wear?
Old Mar 31, 2010 | 07:13 AM
35TH ANY's Avatar
35TH ANY
Default Vandalism or Normal Wear?
I'm thinking vandalism from a disgruntled employee. Your thoughts?
Attached Thumbnails Vandalism  or  Normal  Wear?-dsc01791.jpg   Vandalism  or  Normal  Wear?-dsc01794.jpg   Vandalism  or  Normal  Wear?-dsc01795.jpg
Old Mar 31, 2010 | 07:53 AM
Blooster's Avatar
Blooster
There are other threads here about slices just like yours - some interior sharp edge causes that kind of thing.
Old Mar 31, 2010 | 08:25 AM
flecko28's Avatar
flecko28
^ +1 to this...i've seen these threads around too
Also, this might just be my thoughts, but if it was vandalism, what stopped the person from slicing the whole top? besides just trying to be a pain...
Old Mar 31, 2010 | 08:44 AM
35TH ANY's Avatar
35TH ANY
If it was vandalism, he doesn't have unlimited access to my car to carve it up at will. He would have had to do it quickly and stealthily.
Old Mar 31, 2010 | 08:58 AM
Entaille's Avatar
Entaille
I think you are reaching on the vandalism part, you would have no way to prove it if it was vandalism as well. not an idea worth pursuing much.
Old Mar 31, 2010 | 09:10 AM
Ronin82's Avatar
Ronin82
so how many people have you pissed off then????
Old Mar 31, 2010 | 10:26 AM
SA Z-boi's Avatar
SA Z-boi
I did it im sorry, your just always a jerk to me at work
Old Mar 31, 2010 | 11:07 AM
F34RL355's Avatar
F34RL355
OMFG you vandalized your paint with that metal ruler! that sharp corner is sitting on your paint !!
Old Mar 31, 2010 | 11:36 AM
35TH ANY's Avatar
35TH ANY
It's actually not that much of a reach considering the employee and what's been going down. Agreed that there's no way to prove it. I was just looking for opinions based on the pic. It appears that there are a few similar looking pics posted previously.
Old Mar 31, 2010 | 02:38 PM
fklentz's Avatar
fklentz
That's where the spring arm is that is there to "hold" the rear window up, common failure. I've seen some do it on both sides.
Old Apr 1, 2010 | 08:21 AM
vex008's Avatar
vex008
whats the point, get it fixed and move on.
Old Apr 9, 2010 | 08:05 PM
brianberes's Avatar
brianberes
mine did this on the driver side in the same place. The OEM top material is crap.
Old Apr 10, 2010 | 07:41 AM
Phreakdout's Avatar
Phreakdout
If you're thinking about claiming it on insurance, make sure your story is covered by comprehensive. If you say it happened in your driveway, make sure it doesn't have to be claimed on the homeowner's policy.
Or you could be an honest person and just get it fixed because that tear is normal. Mine happened in the same spot. I found someone with a wrecked roadster and bought their whole top assembly. (Motors and all for $500) I replaced it in less than 30 minutes.
Old Apr 11, 2010 | 01:19 AM
Jennifer 2's Avatar
Jennifer 2
The close up view of your photo clearly shows the tear edges to be worn and frayed from the inside out. The shape and weight of the rear window puts a lot of stretching and stress on the fabric by the four corners of the window when the top is folded down.
Getting a replacement top installed is expensive as hell. The deductible on most policy’s comprehensive coverage is usually only a couple of hundred dollars. I guess I have a lower sense of moral standards than the average member of this forum, because if I could play dumb and get this past the insurance adjuster, I surely would. Unfortunately, most adjusters will spot this as a case of ‘wear and tear’ and not vandalism.
Luckily for you, I’m devilishly good with sharp, jagged implements. A few seconds alone with your car and I could convert that gash into a clear-cut case of insurance coverage eligibility. Just leave the garage door unlocked tonight and the money in the usual spot.
Old Apr 15, 2010 | 02:28 PM
richcity's Avatar
richcity
I have the same exact rip in the same exact spot. I was thinking the same thing about someone vandalizing my car, at one point I even thought it was the birds pecking at it since they love to crap on my car. WTF was I thinking !? lmao!. It started off small and I noticed it was spreading so I came to the conclusion it was caused by the weight of the rear windshield and wind passing through it as I drove with the windows down.
Old Apr 15, 2010 | 02:33 PM
VO...'s Avatar
VO...
Administrator
If I were a P'd off employee and wanted to vandalize your car, I would've sliced that top from end to end. I don't think someone would take the risk to only slice a 2 1/2 inch piece...
Old Apr 15, 2010 | 02:37 PM
350junkie's Avatar
350junkie
either way he has to get a new top?
Old Apr 16, 2010 | 07:04 PM
SHILOW's Avatar
SHILOW
The top ussually tears there, as well as the top corners on the bow at the seams on either side, after 4 or 5 yrs.
sales@czp
Sep 23, 2019 03:30 PM
DarkCreep
Oct 17, 2015 11:50 PM
codek
Sep 28, 2015 03:03 AM
