How to use TIPTRONIC
Old Jun 8, 2010 | 10:38 AM
  #81
SexyRob's Avatar
SexyRob
wow..
Old Jun 8, 2010 | 11:13 AM
  #82
marchockey13's Avatar
marchockey13
Originally Posted by SexyRob
wow..
you have a problem? you guys are over-reacting. I only asked how it worked, big deal
Old Jun 8, 2010 | 11:34 AM
  #83
SexyRob's Avatar
SexyRob
we are not over reacting you are dumb for asking how to use manual mode on the AT
its VERY simple, the engine revs up and you shift. you can shift(up or down) whenever you want depending on your current driving mood. I just don't understand how something so simple can confuse someone.
for all your questions and misunderstanding you really should just leave it in drive.
Old Jun 8, 2010 | 12:36 PM
  #84
Romanteni's Avatar
Romanteni
wow... this is full with fail. Take a driving class dude. No offense that you're new, but you're asking dumbest questions several times. Take a class so you can understand what gears are even for in a car and how they work, at least you won't get flamed for having no idea how the car that you drive operates lol.
Old Jun 8, 2010 | 12:55 PM
  #85
SniperHunter's Avatar
SniperHunter
5th gear on the 5AT is not an overdrive gear. We don't have an overdrive in our cars. Furthermore, the shift delay is nowhere near as long as you make it seem. I know the 5AT was revised in 2005.5, so maybe older Zs are slower, but my 06 responds almost immediately during a shift. Besides, the actual shift happens very quick, it's just the electrical delay that some have mentioned on their older Zs, and I'd attribute that possibly to grounds (people swear up and down the car shifts much quicker with a ground kit). I almost never bounce off the redline. And in 3rd gear, to climb 500RPMs toward redline is a pretty good amount to climb and takes a few seconds - so shifting as early as you say is pointless.
If you wanted to shift at redline in 3rd gear I'd probably give the car 100-200RPMs before the shift (if even). Only in 1st gear would I recommend shifting a bit early to make up for any electrical delay. Also, there is no jerk in the revised 5ATs, as they rev-match on every downshift. And redline is actually 6650 on VQ35DEs.
Originally Posted by *ICE*
if you want speed, gears 2-4 is your choice. 5th gear is overdrive and for gas efficiency and fuel economy. How old are you btw?
Scenario:
you driving on a normal street minding your own business. Street is empty with no traffic and there is no traffic lights for 1/4 mile away. Suddenly, a ricer honda/civic/Scion was next to you and want to race. What you want to do before the race is switch to M mode, it will automatically downshift to 4th gear, you normally can race in 4th but for even more speed, press down on the stick so it would downshift 3rd then floor the gas. When the tachometer's needle reach 6000rpm, press up to up-shift to 4th and same for 5th. Redline is 6500rpm but there is a slightly delay in automatic so do it shifting before that will actually shift the tranny at 6500rpm.
You can also downshift manually to save your brake pads and make it last longer by tap on the shifter. You will feel the car slowing down without pressing the brake pad. Dont go from 2nd -> 1st at high speed or you will feel the jerk. Only downshift from 5 -> 4 -> 3 -> 2
Old Jun 8, 2010 | 01:14 PM
  #86
kyx4n's Avatar
kyx4n
Originally Posted by stevehl
I tried downshifting while in manual mode in my z, and all it did was make the rpms shoot up even though I wasn't applying gas. Thats when i stopped playing with it lol
LOL
wow
Old Jun 8, 2010 | 01:16 PM
  #87
*ICE*'s Avatar
*ICE*
you are wrong. Most car manufactured nowadays will have overdrive gear, which is the highest gear available. Only car that doesn't have overdrive are one that manufactured before 1980 [Source].
Look at the gear ratio for both 6mt and 5at in the attached pic. 5th gear and 6th gear are always the overdrive gear. It's there to save gas by operate the engine at low rpm and for cruising on highway/street, anywhere when speed is above 30mph. This is why the MPG for any auto is less than a manual. Example, in the Z, mpg for highway in 5AT is around 20mpg and 6MT is 25mpg. That is because at 80mph, engine is operate at 3000rpm in 5AT. in 6MT, engine is operate around 2700-2800rpm. Less rpm save gas.
Old Jun 8, 2010 | 04:10 PM
  #88
Arvin89's Avatar
Arvin89
Originally Posted by marchockey13
it wouldnt destroy the car buddy
I agree, i dont know what you guys are all tripping out on, the manumatic has built in fail safes to prevent it from being damaged, and the engine has a rev limiter. The only way you can damage your car by downshifting or not knowing when to shift is by losing control and crashing.
Old Jun 8, 2010 | 04:17 PM
  #89
temoku's Avatar
temoku
are you freakin serious? Do you even know what a transmission is?
Old Jun 8, 2010 | 07:33 PM
  #90
SniperHunter
You have a valid point, but allow me to clarify: the 5th gear in the 5AT isn't a typical overdrive gear. My car accelerates very briskly in 5th gear, where as in other cars, the transmission has a tendency to lock and not allow you to accelerate until you turn OD off (going/sticking to 3rd gear, usually), or just pushing the throttle more until the car downshifts. My Maxima had a 4-speed with OD, and simply put, the 350Z's 5AT is absolutely nothing like that. In the Maxima, there was no such thing as brisk acceleration in 4th gear - that was purely an OD gear - you had get the car into 3rd to do that.
Yes, the gear ratio is below 1.0 in the 350Z, but it locks RPMs to conserve gas electronically and only in D - where as OD engagement before relied on an actual unit within the transmission, I don't believe this is the case anymore, a lot of cars are relying on the ECUs now. And in the 5AT if you're in the Manual Mode, the RPM needle is free to bounce around while you cruise, it's not locked or unresponsive, like an OD gear normally is.
Basically, my point is that the 5AT 350Z's 5th gear is not just an overdrive gear for economy and cruising. It's actually a solid gear for making highway passes no problems.
Old Jun 8, 2010 | 07:35 PM
  #91
mrg1981's Avatar
mrg1981
Originally Posted by MarvinMartian
Not quite.
The anderson bearings in the 350Z's torque convertor are notoriously weak.
You stay in 5 on the highway for more than 17 minutes, I guaran-damn-tee you that you're gonna blow your anderson bearings . . .
If this is some sort of joke, I was not in the loop and don't get it at all.
If this is not a joke...well, it has to be a joke. No way did you just tell someone that they can't drive their car in the highest gear on the highway...that's what the gear is for. Hmmmm...back to my first point...what did I miss that made your post humorous?
Old Jun 8, 2010 | 07:48 PM
  #92
*ICE*'s Avatar
*ICE*
I see your point. Agreed that the 5th gear is also great for passing. It's even greater after my Osiris tuned. The acceleration is top notch and very quick even in D.
Old Jun 9, 2010 | 12:41 AM
  #93
temoku's Avatar
temoku
this thread completely blows my mind, i feel like i'm in the twilight zone
Old Jun 9, 2010 | 06:27 AM
  #94
NewJoyZ's Avatar
NewJoyZ
WELCOME
Old Jun 9, 2010 | 06:28 AM
  #95
Edg_R's Avatar
Edg_R
I was driving home from the gym this morning, and almost recorded myself driving just to post it here.
Haha, he is a troll. He as to be.
Old Jun 9, 2010 | 07:35 AM
  #96
*ICE*'s Avatar
*ICE*
naw he is not. He's a 22 years old french-canadian who is a hockey fan and drive an auto convertible 05 Z. At least he speak better English than most 17 yrs old American on this forum
http://forums.nicoclub.com/which-mod...z-t430034.html
Old Jun 9, 2010 | 08:27 AM
  #97
marchockey13
Haha thanks man. And in reality i am 19 years old, i probably just entered a fake birthday on this website... But yup, i am a french canadian from Montreal lol
Old Jun 9, 2010 | 09:23 AM
  #98
Edg_R's Avatar
Edg_R
They clowned on him there too lol.
Nissan_luver08:
wow, look at that attitude! My guess it was a Roadster with the Touring package, thats what most of them are. I mean, coming for a guy that doesn't even know where to find the VIN, I am surprised you knew this was even a Z car..
kuhan:
Dude, don't get me started man. You're 22 yrs old and don't even know where to find where the VIN? How pathetic!!! Go read books, nerd!
snwbrdr435
I sure as hell don't atleast this f***tard is leaving
Maybe that's why he came over here.
Seems like we're a rougher crowd though.
Old Jun 9, 2010 | 05:53 PM
  #99
SniperHunter
Yep, same here.
Old Jun 10, 2010 | 11:46 AM
  #100
JCat's Avatar
JCat
http://www.youtube.com/watch?v=oIS5n...layer_embedded
