Intermittent starting problem
Old Sep 6, 2010 | 03:46 AM
2004zroadster's Avatar
2004zroadster
Question Intermittent starting problem
Has anyone experienced an intermittent starting problem where the security system temporarily does not recognize the key and generates a fault code "1615?" After a minute or so, of repeated attempts to start, the car fires right up. I had new keys made and programmed but the problem still occasionally raises its head mostly after short trips. I think it may be the ignition switch. Nissan dealer thinks either that or computer. Any thoughts?
Old Sep 6, 2010 | 04:56 AM
pmab9918's Avatar
pmab9918
Here are a few threads about it, good luck.
https://my350z.com/forum/search.php?searchid=12195923
Old Sep 6, 2010 | 06:09 AM
2004zroadster
Thanks. Looks like a common problem but without a definite solution. Bummer...
Old Sep 25, 2010 | 01:17 PM
2004zroadster
As an update, took car to Nissan dealer and left it for over a week. Never acted up for them. I got it home and that night, it did it again. And has repeatedly done it since. What I have found that seems to work is that when it does not start, I take the key out of the ignition, open and close the door, put the key back in and the car has always started on the first try. Crazy problem...
Uriyo_
Sep 8, 2021 08:46 AM
