Where is the best place for subs in roadster?
Old Jan 21, 2012 | 06:58 AM
twiznitch's Avatar
twiznitch
Originally Posted by TURBOROADSTER
That is correct , take out the steel factory sub mounting plate on drivers side , bolt this box in using the same hardware . Passenger side , remove oem glovebox , and bolt box in . I have 1 box for sale at $60.00 shipped(unloaded)or $100.00 shipped with a Pioneer Premier 10" dual 4 Ohm driver loaded into the box . Was used one summer and never abused . Wire the driver in Parallel and your mono amp will see a 2ohm load .
SOLD! Paypal sent for unloaded sub box.
Old Jan 23, 2012 | 01:55 PM
TURBOROADSTER's Avatar
TURBOROADSTER
Anyone have a Oem metal Sub bracket that your willing to part with ?
Old Jan 30, 2012 | 03:58 PM
TURBOROADSTER
Originally Posted by 04blueroadster
Can anyone reccomend where to get an enclosure for the roadster besides eBay?
(I'm within the Greater Toronto Area well)
THANKS!!
Your car already comes with a good enclosure, all you need is to buy another(Ebay) . You can then have two front firing 10" subs . It just takes a little work . I did this mod to a buddys 350Z , and i am currently doing it to my Roadster . End result sounds 10X better than the CAS or SRQ boxes , massive tight bass with no rattles . (I've used the SRQ and heard the CAS) Pictures will be up soon .
Old Feb 1, 2012 | 09:12 PM
johndoesdamage's Avatar
johndoesdamage
Can you post pics? I'm installing a 10 this weekend and want to know what you guys are doing? Do you mount the sub on the metal bracket and leave it open? Or remove bracket and set a box in its place? How's the rattle there? Dynamat?
Old Feb 2, 2012 | 03:21 AM
TURBOROADSTER
Do not use just the bracket alone , you will get no bass . I have found that using the OEM glove box as your sub box , with the oem sub bracket mounted to the glove box ( The glove box does have to be sealed up air tight) will yeild the best rattle free bass . Unless you build a fiberglass front firing box . I will have picks up by this weekend of what had to be done .
Old Feb 3, 2012 | 10:19 AM
TURBOROADSTER
I have posted my glove box sub box mod into the audio section .
Old Feb 3, 2012 | 11:02 AM
johndoesdamage
cool gonna check it out...
Old Feb 6, 2012 | 04:22 PM
johndoesdamage
Anyone know where I can find a 8" box sealed or ported online...I'm trying to make it fit inside the cubby hole behind driver seat
Old Mar 22, 2012 | 10:11 PM
angadoneal's Avatar
angadoneal
I have a 07 roadster with a vs3 kit and was debating the same whether to go with the trunk or the spaces behind the seats and where it would rattle the least. I ended up getting 2 twelve inch Kicker L7's in the trunk. Just remove the spare wheel cut out the bracket holding it and you have ample room to drop in a pretty big box with what looks like floor mounted subs
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
Tochigi_236
Sep 27, 2015 03:40 PM
