Where is the best place for subs in roadster?
Old Sep 3, 2011 | 10:33 PM
KiZeeZee's Avatar
KiZeeZee
Default Where is the best place for subs in roadster?
I don't know if i should put one sub in the trunk (not much room ) or behind the seat. i also had subs in a bmw and it rattled EVERYTHING and my z has a body kit so how will that sound?? any suggestions??
Old Sep 3, 2011 | 11:14 PM
HipHop615's Avatar
HipHop615
I have a Wicked CAS fiberglass box and 13" sub behind my drivers seat. if you put it in the trunk yu will have zero room for anything.
Old Sep 4, 2011 | 06:09 AM
Mint Racer's Avatar
Mint Racer
go for the stock location box. u can also try SRQ custom sound roadster box, it can be cut for 10, 12, or 13. made from mdf and fiberglass, and lower cost, sounds great!!
Old Sep 4, 2011 | 06:39 AM
Dealsgap's Avatar
Dealsgap
Default How about the Infinity BassLink II sub
I don't have a roadster but I did replace my entire system and added the Infinity BassLink II sub in the stock location. I'm impressed with it although some might want more. Just a thought...
Old Sep 4, 2011 | 02:17 PM
w210e55's Avatar
w210e55
Default sub in roadster
I have the srq with a 13 inch JL flat sub where the bose sub normally goes behind the drivers seat as well and it sounds great. just be careful when you remove the trim, it's tight and I snapped off two clips pulling it off.
Old Sep 14, 2011 | 01:45 PM
ZPHILE's Avatar
ZPHILE
This is what I have too and highly recommend it. Mine is the first iteration 10" box. But I'm more than happy. "Crazy" folks even do two of these with one in the stock sub location and another taking up the storage cubby. BTW - I have two amps, one for the regular speakers (tweets/mids) and one for the sub. One under each seat with no issues after years of usage. Also, you can check out my setup here:
https://my350z.com/forum/members/633...-roadster.html
Old Oct 4, 2011 | 06:37 AM
tomasito's Avatar
tomasito
can you post a pic of the baslink in the stock location?
Old Oct 14, 2011 | 11:31 AM
John H.'s Avatar
John H.
I concur with ZPHILE, as the best location for the sub is in the interior, utilizing the space where the existing sub exists. I transferred my sub from trunk to interior, and it made a world of difference.
Old Oct 15, 2011 | 01:52 PM
Tenny's Avatar
Tenny
IF you're okay with the trunk being basically even more gone than it already is, then yeah haha. trunk works. I have a set up being ready to be put in for the stock location. From what i've seen it just works better there, and sounds better.
Old Nov 1, 2011 | 05:42 PM
golfguy's Avatar
golfguy
I also have an Infinity Basslink behind the drivers seat in the stock location and it hits plenty hard enough for me. Made a huge difference in the sound of the Bose system before I ripped it out and replaced it with an Alpine/Infinity setup. Sounds even better now.
Old Nov 14, 2011 | 08:23 AM
John H.'s Avatar
John H.
I have 2 SRQ boxes, with Kenwood Excelon 10" subwoofers. Running a Excelon XRS1 amp, under pass. seat. Sound 100x better vs. subs in trunk.
Old Nov 17, 2011 | 12:37 PM
John H.'s Avatar
John H.
New sub cover/grill.
Old Dec 3, 2011 | 02:09 PM
block8head's Avatar
block8head
where did you get the left sub cover?
Old Dec 5, 2011 | 11:16 AM
John H.'s Avatar
John H.
It is the same as driver's. Ordered it from Kenny at Duarte Nissan.
Old Jan 12, 2012 | 07:47 PM
johndoesdamage's Avatar
johndoesdamage
Where do I get these srq boxes? I'm looking for 2 10" inside each cover,can someone post a pic of this srq box?
Old Jan 15, 2012 | 10:53 AM
TURBOROADSTER's Avatar
TURBOROADSTER
Bought mine off ebay , I am selling my 350Z and getting a 370 , I will have one for sell in about a week if anyones interested .
http://www.ebay.com/itm/Nissan-350z-...item3a5ccba9ef
Old Jan 15, 2012 | 03:50 PM
johndoesdamage
So When you install it you get rid of the stock sub bracket and bolt this in...is it the same thing on the passenger side minus deleting the glove box?
Old Jan 15, 2012 | 09:11 PM
04blueroadster's Avatar
04blueroadster
Can anyone reccomend where to get an enclosure for the roadster besides eBay?
(I'm within the Greater Toronto Area well)
THANKS!!
Old Jan 16, 2012 | 07:44 AM
TURBOROADSTER
That is correct , take out the steel factory sub mounting plate on drivers side , bolt this box in using the same hardware . Passenger side , remove oem glovebox , and bolt box in . I have 1 box for sale at $60.00 shipped(unloaded)or $100.00 shipped with a Pioneer Premier 10" dual 4 Ohm driver loaded into the box . Was used one summer and never abused . Wire the driver in Parallel and your mono amp will see a 2ohm load .
Old Jan 20, 2012 | 10:16 AM
twiznitch's Avatar
twiznitch
I'll take the box unloaded, you have a PM
