Passenger window stuck fully open on ragtop.
Old Mar 8, 2012 | 05:11 PM
Silver DAB's Avatar
Silver DAB
Question Passenger window stuck fully open on ragtop.
Help. Passenger window is stuck in the fully up position. Switch can be heard clicking (when pressed from either drivers or passenger door switch. The auto advance 1/8 inch movement of the window on door closing isn't working either but again door pillar switch is good as i can hear it clicking in the
door panel.
Rag top procedure requires the windows to auto roll down so currently stuck... Any ideas ???
Car is 2008 with 39,000 on clock.
Old Mar 8, 2012 | 11:53 PM
goracerx's Avatar
goracerx
That's scary I have a 2008 also. I think the click is the auto hold but just because the switch itself moves, the connection could be bad but you said they both won't work. First thing I would do is look in the owners manual trouble section. If the drivers window works then fuse would be ok as they should be on the same one. I think the next thing I would do is take the passenger door panel off and check the mechanical parts. It could be a broken little plastic part that snaps a rod in place or the glass is off track or crooked. It may not be broken. If it's off track there could be like a safety stop, so the glass doesn't fall down or break.
350Z_Al
Oct 29, 2020 07:44 PM
Jambo016
Sep 16, 2016 01:08 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
samansharif
Sep 25, 2015 12:31 PM
