Elastic Bands? Video Attached!
Old Jan 15, 2013 | 01:34 PM
red roadster's Avatar
red roadster
Originally Posted by patrickoneal
That was my thread. If I did it over again, I'd try to find something a little better than cardboard to protect the top. I didn't slip, but I doubt it would offer much protection. The hardest part is punching the rivet nubs through after drilling the head off. I could have used a larger bit and drilled it out rivets completely, but I was concerned about enlarging the hole and the new rivets not holding. Definitely put down a towel to catch all the aluminum shavings, I made quite a mess.
I see you mentioned using some elastic material sourced from a craft store. I think this would be difficult to attach with rivets. The latest OEM straps are double thick, and I think they're tripled up and sewn at the ends where the rivet holes are. If you have a sewing machine and some leather punches, you could probably duplicate the design, but for the price of the OEM strap kit, I think it's the better way to go.
I've got some extra new OEM straps, I can measure the rivets, hole spacing, length, and document the folding and stitching if you like.
Just finished replacing the bands, piece of cake. The materials worked good. Did use a leather punch to make holes for rivets but again was easy job.
Old Jan 16, 2013 | 06:18 PM
Slyguy_38's Avatar
Slyguy_38
Originally Posted by red roadster
Just found the tread on using the two sided tape. Last post date 12-4-12, not sure if the paste below will work.
Tread title " Replace Elastic Bands (no drilling)
https://my350z.com/forum/350z-roadst...-drilling.html
I only have problems with the top opening when it hasn't been in the sun for a while and it's cold out. Then it will stick part way open and I have to cycle it a few times to get it down. No other problems with it yet and I'll use this method instead of drilling out the rivets when I do...
Ryan
Old Jan 21, 2013 | 03:59 AM
SHILOW's Avatar
SHILOW
Originally Posted by Cavallino
Can you be more specific on pushing the 2nd bow into position???? I am having a similar problem as the car in the video posted by the OP. However, it is winter and very cold where I am in New York, and I know you're technically not supposed to open/close the top in cold weather, but I just bought the car and wanted to make sure it worked. I did lube some of the moving parts up, and it went down fine, but now it is stopping just before going in, like the car in the video.
As the top is opening the second bow is supposed to be pulled towards the back by the elastic bands to position it for the fold. When the top is pointing in the air, reach back and push on the bow to assist the elastic bands.
Old Sep 25, 2024 | 11:17 PM
Cynthia105's Avatar
Cynthia105
Hey, had a similar issue with my Z. Check if the wiper motor or linkage is acting up, often it's not just a re-indexing thing. Could be the park position messing up, causing them to sit wrong.
Also, sometimes adjusting the wiper arms helps, but best do it with someone who knows their stuff.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
