Project: Nismo roadster
Old Jun 28, 2016 | 10:03 AM
  #501
DeusExMaxima's Avatar
DeusExMaxima
Originally Posted by StarkdrivenZ33
I have considered this soooo many times please let mee see it completed.
Completed how?
Old Jun 28, 2016 | 10:12 AM
  #502
DeusExMaxima
Originally Posted by 0taku
I considered it. However, if you look at the lines of the DE hood, you will see that they match up exactly with the front center part of the Nismo bumper.
Old Jun 28, 2016 | 10:51 AM
  #503
travlee's Avatar
travlee
Master
did it crack around the filler where the emblem should be?
or whats going on there?
Old Jun 29, 2016 | 10:44 AM
  #504
DeusExMaxima
This is kind of the like "Red Dot" episode of Seinfeld where George bought a really expensive cashmere sweater with a deep discount for Elaine because the sweater had a red dot on it and he was hoping she wouldn't notice. I was hoping no one would see it but.....yes, the filler seems to have cracked even though I bought it at a body shop and it is meant for filling bumpers. When I respray the car, Ill figure out what to do about it.
Old Jul 4, 2016 | 10:34 PM
  #505
myork's Avatar
myork
You can not fill a depression that deep with bondo, it will always crack or fall off. It needs to be filled with poly filler and then skinned with bondo - preferably less than 1/8" thick.
Old Jul 7, 2016 | 08:51 AM
  #506
NiLL's Avatar
NiLL
Old Jul 10, 2016 | 02:04 PM
  #507
DeusExMaxima
I used proper bumper filler from a professional Body Shop Supply Store.
Current pics of Nismo 350Z roadster:
Old Aug 17, 2016 | 10:52 AM
  #508
DeusExMaxima
Driver's side window doesnt roll up or down any more.....grrr
Old Aug 17, 2016 | 12:14 PM
  #509
Heel Til I Die's Avatar
Heel Til I Die
Suck! I'm sure you've seen this DIY.
https://my350z.com/forum/maintenance...dow-motor.html
Hopefully it's not too much of a PITA for you.
Old Aug 19, 2016 | 05:15 PM
  #510
Resmarted's Avatar
Resmarted
I had to replace both window motors, drivers side twice. That's just the car man.
Old Aug 25, 2016 | 01:40 PM
  #511
DeusExMaxima
I will have to pull the door cards and make sure power is getting to the motor. How do these motors fail...dirt? Is the consensus among everyone to just replace the motor and not try to clean it?
Old Aug 25, 2016 | 02:02 PM
  #512
travlee's Avatar
travlee
Master
Cleaning is a temp fix
Old Aug 26, 2016 | 06:47 AM
  #513
GreyZ's Avatar
GreyZ
It has a few things here and there, but this is the best looking roadster I have ever seen
Old Sep 1, 2016 | 08:47 PM
  #514
Resmarted's Avatar
Resmarted
Yeah if the motor is not working at best cleaning will help it work for a bit longer. Every window motor I've seen get cleaned works for anywhere between not at all, a few minutes and a day or two. Not really worth the hastle of taking it all apart only to have to go back and do it again.
Old Sep 13, 2016 | 10:26 AM
  #515
francee's Avatar
francee
Default My Blue Roadster
Very Nice Roadster! I had considered a Nismo kit for mine but the cost was too much at the time. I went with carbon fibre C-West and Siebon body parts. Also, ProjectX upgraded the engine with a Vortech Supercharger.
Mine's for sale.
Attached Thumbnails Project: Nismo roadster-img_0538.jpg   Project: Nismo roadster-img_0658.jpg   Project: Nismo roadster-img_0808.jpg   Project: Nismo roadster-img_0805.jpg
Old Sep 20, 2016 | 01:00 PM
  #516
DeusExMaxima
Francee and Grey: Thank you kindly. Its been quite a bit of work.
UPDATE: I went away for 9 days and, strangely, the window now works. Maybe the Nissan elves came in the middle of the night and fixed it?
Old Oct 6, 2016 | 12:20 PM
  #517
DeusExMaxima
UPDATE: The window stopped working again but I have the strangest temporary fix. I find that if I open the door, press the window button and close the door while the window button is pressed, the window starts working again. Obviously I need to open the door up and make a fix, but it kinda works for now.
I have a list of things that need attending to:
1. The rear Nismo bumper pulls away from the car on the right side. The attachment hole on the bumper is broken. Im thinking of epoxying a washer on the underside.
2. Fix or replace the drivers window regulator.
3. Brakes are shimmying. Need to machine or replace front rotors.
4. The upper part of the driver seat does not heat when heater is turned on. Most likely a broken wire in the heating pad.
5. I have some curb rash on my beautiful right rear Nismo wheel...I guess Ill need to get some paint.
6. My gas gauge is acting up again even though I cleaned the sending units....ugh
Old Oct 13, 2016 | 12:35 PM
  #518
DeusExMaxima
Window issue: Its strange but if I dont roll the window all the way up, it operates normally. If I leave it up all the way, then it works intermittently....weird.
Old Oct 18, 2016 | 04:35 PM
  #519
DeusExMaxima
I got a tip from AffyliatedZ regarding having my GTR shift **** fit better. I never liked the fact that the shift **** was kind of Wiggly on the shifter shaft. The tip was to get a pencil grip cushion and put it on the **** about three-quarters of the way in and then hit the **** on to the shaft. I ordered some cushions and they should be here in a couple of days so I will keep you all posted and thank you again to Affyliated Z. Hopefully it works out good for me as it did for you.
Old Oct 21, 2016 | 09:47 AM
  #520
DeusExMaxima
I got the pencil cushions yesterday and yanked my GTR **** off to fiddle with it. After a bit of fiddling, I got the cushion to work and the shift **** is solid. I do have to push down a bit when shifting into park but it feels much better. Thanks AffyliatedZ!!
