My convertible won't fully close.
Old Mar 8, 2016 | 07:44 AM
Will Sanchez's Avatar
Will Sanchez
Exclamation My convertible won't fully close.
Hey guys! Well recently, I bought a 2004 Nissan 350z Roaster and it has some cosmetic issues! My convertible was forced open from the back end and top end. The convertible top opens and closes but when I put the top on, it won't fully close all the way (leaving 1 inch gap in the back end). It won't fully seal and in the speedometer, it will show me the convertible icon in orange. Any help guys? I'd really appreciate it!
Old Mar 8, 2016 | 08:20 AM
travlee's Avatar
travlee
Master
http://lmgtfy.com/?q=My+convertible+...e%3Amy350z.com
Old Mar 8, 2016 | 09:07 AM
jhc's Avatar
jhc
General & Tech Moderator
If I understand your question correctly, your top doesn't close all the way after replacement, yes?
When I replaced mine DIY, I found the same problem. Just let the back latch the hook completely, then use your weight to pull silver front latch forward and down. It will stretch in a few weeks. gl
Old Mar 15, 2016 | 01:25 PM
DeusExMaxima's Avatar
DeusExMaxima
My top wont close either. It got stuck about 3 inches from closing. It wont go either direction, like its wedged. My top isnt new and its been a bit sticky in the past.
Old Mar 15, 2016 | 01:36 PM
jhc's Avatar
jhc
Forgot to mention, there is a small rocker switch on the driver side frame. I bent it slightly when I did my top, p1ssed it's very expensive.
It basically tells the control module when the 5th bow is down to kill power to the motor. I was able to straighten it with hemostats/needle-nose. No leaks or wind noise.
I don't have a schematic, sorry.
Old Mar 22, 2016 | 04:52 AM
mreed772's Avatar
mreed772
What do you mean by forced open? Mine just needed to be exercised since the previous owner did not use it often. But if it was forced open you may have some damaged components.
Old Apr 13, 2016 | 12:46 PM
sluggoZ's Avatar
sluggoZ
http://www.myzroadster.com/Files/tsb.../NTB03-122.pdf
Old Apr 13, 2016 | 05:06 PM
jlb's Avatar
jlb
First time I'm seeing this. Thank you.
Old Apr 14, 2016 | 10:49 AM
DeusExMaxima
I fixed my top for the moment. I found that there is a small piece of plastic, about 3"x3" that has a spring steel rod through it, about like a paperclip, that opens and closes when the top goes up or down. I found that it jammed the mechanism so it woould move. I got the piece out, fixed it and installed it. I was then able to close the top so the coming rain wouldnt get in
evil350zdriver
Sep 14, 2016 11:37 AM
StreetStandard
Mar 29, 2016 12:59 PM
Wiring_Specialties
Mar 2, 2016 02:17 PM
EnjukuRacing
Drivetrain
Mar 2, 2016 05:43 AM
