Window Motor Shaft Alignment
Old Aug 11, 2016 | 11:12 AM
Kevin Kearney's Avatar
Kevin Kearney
Default Window Motor Shaft Alignment
I'm replacing the driver's side window motor. The flats on the new motor shaft do not line up with the socket in the gear box. I assume I don't want to turn the gearbox. I tried turning the new motor with a small wrench - doesn't budge. How do I turn the motor to align the shaft with the gearbox socket?
I'm probably missing something pretty simple.
Thanks,
Kevin
Old Aug 11, 2016 | 12:04 PM
iideadeyeii's Avatar
iideadeyeii
Stick the square in the square hole then turn the motor(window will move up, if it doesn't do it the counter way of the way you just did.
You probably have to reset the auto down/up after
Old Aug 11, 2016 | 03:32 PM
Kevin Kearney
Thanks - I just put 12V on the new motor and got it to the right position.
Kevin
ianeberle
Sep 20, 2016 06:26 PM
trains1937
Jul 3, 2016 10:32 AM
engiman34
Jun 30, 2016 05:06 AM
Turbo_Tay
Jun 9, 2016 11:04 AM
35th4me
Jun 1, 2016 06:58 AM
