Gearbox
Old Oct 11, 2018 | 05:02 PM
Sophie China's Avatar
Sophie China
Default Gearbox
So I just got my car back last night from a mechanic that replaced my gearbox that was slipping. Now the car has no power! Going up hill a bit it won’t go above 30km/h, won’t ahift into gear until the revs hit about 4-5 and takes so much longer to even get up to 60km/h. Haven’t even been able to get it above 70km/h. When I hit the accelerator it either doesn’t respond or is delayed. Anyone have a problem like this or even a solution? Thanks
car is 2005 auto 350z
Old Oct 11, 2018 | 07:41 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
First, please don't double post. Causes confusion and clutter.
Secondly, why aren't you asking the person who worked on the car instead of the forum? You'll get guesses here, lots of them and likely ONE of them will be correct; but none that anyone can confirm without hands on, which your "mechanic" had and will have to fix it. I mean it's clear that it's gone into limp home mode (or something close), likely crank position sensor, affected by transmission removal in the vicinity (see, a guess). Other thing, did you pull the DTC?
Old Oct 13, 2018 | 09:11 PM
Sophie China
Sorry didn’t realise I posted twice. So the mechanic that did the work couldn’t figure it the problem and that made me kinda lose trust. I’ve taken it to a new mechanic since. But wanting to see if anyone else had the same problem
CAR2
Australia/New Zealand
19
May 13, 2004 03:29 AM
mrZeee
May 5, 2004 09:27 AM
CAR2
13
Nov 8, 2003 11:13 PM
