XM Radio
Old May 24, 2004 | 04:48 PM
theSmoothDome's Avatar
theSmoothDome
Default XM Radio
I'm considering putting XM radio in the roadster. The installer I talked to says that with the new micro antenna he can hide the antenna somewhere inside the tonneau cover of the car. He says that the signal will travel through fiberglass. Sounds good to me if it can be done that way.
My biggest problem is where to put the receiver. There doesn't seem to be a good place for it. Anyone out there have satallite radio in their ZR? Where did you put the receiver. Pics would be wonderful . While we're at it, where did you put the antenna?
Old May 24, 2004 | 06:52 PM
Z33Concept's Avatar
Z33Concept
PUT the reciver where the nav would go thats a nice spot for it
Old May 24, 2004 | 07:01 PM
theSmoothDome
Good idea, except I have the nav
Old May 25, 2004 | 07:50 AM
Steve Parsons's Avatar
Steve Parsons
Without the Nav display I installed my receiver in the center compartment with the FM modulator and antenna wire concealed in the dash. With a small notch in the top of the center dash panel the antenna rests between the gauges and the windshield. Works great. Have you considered an XM ready radio. I have one in my boat. It's not protable but may solve your problem.
Steve
Old May 30, 2004 | 03:47 AM
Chief F1 Fan's Avatar
Chief F1 Fan
the receiver is so small for the commander couldn't you just install it at the top left of the passenger footwell as far up as possible? I just got mine Friday so I have to find a good installer to have it put in. It has to look as stock as possible.
Old May 30, 2004 | 04:53 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
By "reciever" do you mean the "brain" of the unit or do you mean the part that has the buttons and display you use to change the channels?
If you mean the brains, I have mine under the passenger seat. Another place is under the "hidden" compartment in the glove box.
If you mean the other small unit, I have mine just under the three climate control *****.
I've seen others put it un in the sunglass holder but you probably don't have that in the roadster (or do you?)
Old May 30, 2004 | 07:02 AM
mgk65's Avatar
mgk65
I have some pictures of an XM Commander install in my 2003 Z here:
https://my350z.com/forum/showthread....threadid=72961
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Sailors350Z
Sep 25, 2015 08:21 AM
koolzero
Nov 22, 2002 06:07 PM
mcclaskz
Nov 13, 2002 10:17 AM
