370Z Wheels & Tires 370Z Rims and treads
Anyone having trouble with the TPMS???
Old Apr 2, 2009 | 08:51 PM
mrrrkva's Avatar
mrrrkva
Default Anyone having trouble with the TPMS???
I cant get mine to go off?? I have all four tires at 39 psi. Any suggestions?
Old Apr 2, 2009 | 09:09 PM
lww's Avatar
lww
The one I drove wouldn't go off either, but I expect it's because they replaced the 19" Rays with 20" wheels from an '08 GT-R...
Old Apr 3, 2009 | 02:51 AM
BGuess's Avatar
BGuess
Nope, no trouble here.
Old Apr 3, 2009 | 05:26 AM
WhiskeyHotel's Avatar
WhiskeyHotel
Take it to the dealer and let them do their magic. Bring lube.
Old Apr 3, 2009 | 08:53 AM
tylerxfire's Avatar
tylerxfire
Originally Posted by lww
Mine won't go off either, but I expect it's because I replaced the 19" Rays with 20" wheels from an '08 GT-R...
pics?
Old Apr 3, 2009 | 09:49 AM
davidmcc's Avatar
davidmcc
The system has to be reset.
If you changed sensors and the computer has to learn new TPM sensors there aren't many options other than the dealer, unless you can find a tire shop that has the very latest TPMS tools and software.
If you just need to relearn the sensors that were already on the car you can do that yourself. OTC makes a tool that can do this and I've actually seen it for sale at a local pep-boys.
First, tire pressure must be adjusted according the Nissan specs for relearning the vehicle. This is usually FL – 36 psi, FR – 33 psi, R – 30 psi, LR – 27 psi. The tool connector mates to a connector on the Nissan located behind or near the DLC connector. It is often mounted behind the fuse panel under the dash. The alligator clip must grounded on bare metal. Triggering the tool 5 times within 10 seconds will cause the TPMS warning light to begin blinking. Disconnect the tool and trigger the sensors by either driving the vehicle at a steady speed over 30 mph, or use an RF based TPMS tool like K-Tool’s PST or TIPS tool. This will extinguish the TPMS warning light completing the procedure. Finally, adjust tire pressures accordingly.
Old Apr 3, 2009 | 07:12 PM
mrrrkva's Avatar
mrrrkva
Its a brand new car. 400 miles on it now, Never changed the tires? Worth taking in to get it fixed?
Old Apr 3, 2009 | 10:55 PM
davidmcc's Avatar
davidmcc
If it's a brand new car then YES, absolutely get it fixed, with only 400 miles it's obviously some type of malfunction and should definitely be covered under warranty.
Old Apr 3, 2009 | 11:10 PM
tylerxfire's Avatar
tylerxfire
yeah is it even a question. if its a new car like that obviously somethin going on..get it checked out, not gonna cost u anything
Old Apr 16, 2009 | 06:35 AM
melloyello370's Avatar
melloyello370
If it's a brand new car under warranty... just take it in.
Old Apr 16, 2009 | 10:09 AM
Solito_600RR's Avatar
Solito_600RR
I have the same problem... Have you used this tool? Does it really work?
Thanks
pslamp32
Feb 8, 2017 09:07 AM
kyin
Oct 15, 2015 05:54 AM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
