Jl 1000.1 have a bult in Hi low converter?
Old Nov 24, 2004 | 02:20 PM
CopperZ's Avatar
CopperZ
Default Jl 1000.1 have a bult in Hi low converter?
I have jl 1000.1 in the mail, but i took my dash apart today and wanted to know if the JL 1000.1 has a Hi/low converter bult in the amp. i have a jensen hi low converter but dont want to put it in, if the amp has that feature.
Im keeping the stock bose HU.
Oh and does anyone know which wires to cut into on the HU???
Old Nov 24, 2004 | 02:33 PM
hndumafia's Avatar
hndumafia
you can cut a rca cable. then wire the cut end of the rca to the high volt output and connect the rca cable to the amp like normal. then on the amp change the setting to high volt input. it is in the manual that comes with the amp, not just a random idea btw.
Old Nov 24, 2004 | 02:45 PM
CopperZ's Avatar
CopperZ
which on would be the high volt output???
thanks
Old Nov 24, 2004 | 02:46 PM
hndumafia's Avatar
hndumafia
you can splice into the speaker wire from one of the rear speakers.
Old Nov 24, 2004 | 02:49 PM
CopperZ's Avatar
CopperZ
Rears are not as "loud" as the front. Or it dosent matter? Also neg speaker wire to black rca and pos speaker wire to red rca i assume.
Old Nov 24, 2004 | 02:51 PM
MIAPLAYA's Avatar
MIAPLAYA
I wouldn't splice of the rear speakers...Those signals are already amplified by the Bose amp. I would tap off the HU signal output to get the correct full frequency. The best thing to do is pick up a PAC hi-lo converter from your local audio shop and use that. Then you dont have to cut the wires you just use a wire tap to get the signal.
Old Nov 24, 2004 | 02:55 PM
hndumafia's Avatar
hndumafia
woops i didn't know he had a touring model. i never even think about bose since i dont have it. i guess you could splice one of the front speakers behind the radio, or you could get the pac convertor made for the bose system as miaplaya said.
CopperZ's Avatar
CopperZ
Anyone know which wires are which in the back of the HU? Anyone have a diogram?
Old Nov 24, 2004 | 03:00 PM
MIAPLAYA's Avatar
MIAPLAYA
What I would do and this is just me and what I usually do is go to the store and by a harness adapater and a reverse harness adapter. Then you splice in the Hi-Lo converter and connect the two. Kind of like an extension of the harness with the hi-lo tapped in...
Harness adapater
Reverse adapter
You just splice the converter in between and connect the two then plug and play it.
Old Nov 24, 2004 | 03:05 PM
hndumafia's Avatar
hndumafia
that is an excellent suggestion by miaplaya so you dont have to splice into your stock harness.
here is the diagram of the bose wiring just in case you need it for anything.
front speakers bose.
Attached Thumbnails Jl 1000.1 have a bult in Hi low converter?-frontbose.jpg
Old Nov 24, 2004 | 03:06 PM
hndumafia's Avatar
hndumafia
rear speakers bose.
taken out of the z service manual btw.
CopperZ's Avatar
CopperZ
Harness adapater
Reverse adapter
I think ill do that, but still dont know which wires are which....
hndumafia's Avatar
hndumafia
you do now
Old Nov 24, 2004 | 03:11 PM
MIAPLAYA's Avatar
MIAPLAYA
Thats the thing...with the harness you dont need to know what the stock wire color is. Each of the wires on the harness are labeled as to what they are so you can tap and connect them very easily.
Old Nov 24, 2004 | 03:16 PM
CopperZ's Avatar
CopperZ
Yea i guess so.. Now i got to find these bad boys somewhere... any place in mind guys?
Old Nov 24, 2004 | 03:17 PM
MIAPLAYA's Avatar
MIAPLAYA
Go here...
http://www.scosche.com/applications.aspx
Old Nov 24, 2004 | 03:18 PM
MIAPLAYA's Avatar
MIAPLAYA
http://www.scosche.com/scosche.aspx?...&CategoryID=78
http://www.scosche.com/scosche.aspx?...&CategoryID=44
Old Nov 24, 2004 | 03:19 PM
CopperZ's Avatar
CopperZ
AOEM-NIS2 is a Auxiliary Audio Output for Nissan and Infiniti w/ Bose. i would get that but some websites say its up to Bose from 1995-2005 some say up to 1999 others say 2002... Anyone used this on a 03 Z?
Old Nov 24, 2004 | 03:23 PM
CopperZ's Avatar
CopperZ
$30 for the 2 wires w/out ship i would rather get the hi low converter or the AOEM-NIS2
Old Nov 24, 2004 | 03:29 PM
MIAPLAYA's Avatar
MIAPLAYA
Oh dude I would totally buy that kit. MUCH easier plug and play...It should work fine. Nissan hasn't changed adapters since 95.
