two questions:headunit wiring diagram with colors help and sub panel removal
Old Dec 13, 2004 | 05:58 PM
chaofun's Avatar
chaofun
Default two questions:headunit wiring diagram with colors help and sub panel removal
I just took out my headunit in my 2004 non bose 350z. I want to hook up a headunit to it, but my wiring harness seems to have the wrong colors. Does anyone have a headunit wiring diagram with the colors and what the colors mean? I need to match up the correct colored wires with the new headunit.
Also, does anyone know how to remove that metal panel behind the drivers seat (where the stock bose sub would go)? I could easily remove that plastic panel. How do I remove the metal one?
I've been searching a long time for these answers but was unable to find exactly what I needed. Any help would be greatly appreciated.
Old Dec 13, 2004 | 06:36 PM
westpak's Avatar
westpak
SFZCC
As for the sub panel it just pulls out.
Old Dec 13, 2004 | 06:59 PM
chaofun's Avatar
chaofun
Thanks for posting this diagram. I am confused though. Are there colors and what the colors mean labeled here?
I've already pulled out the plastic panel. How do I remove the metal one?
Old Dec 13, 2004 | 08:38 PM
gt3's Avatar
gt3
To remove the metal plate, you will have to remove the large plastic piece which surrounnds both the glove box door and the subwoofer plastic cover. First you will have to remove both door sills and rubber mouldings, then the side plastic panels in back of the doors and lift up the center console. Check this post for more info and pics:
DIY LINK
Old Dec 14, 2004 | 04:23 AM
westpak's Avatar
westpak
SFZCC
The colors ar basic just look at the abbreviation, like BR means brown, Y means yellow, GW means green with white.......
Old Dec 14, 2004 | 05:08 AM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
Also make sure you look at the notes on the top right. Colors chage whether you have an A/T or Nav unit.
Old Dec 14, 2004 | 05:13 AM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
You also might want to check out this link. I helped Zquicksilver with basically the same issue about a month ago
https://my350z.com/forum/showthread....threadid=99865
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
