amp location...
Old Dec 15, 2004 | 10:52 AM
530_350's Avatar
530_350
Default amp location...
hey do any of you guys have your amp on the carpet right behind the driver seat? cuz im getting a box from nazar for under the strut, and i dont know if i should put it there or in the compartment behind the passenger seat. I popped open the compartment behind the driver seat but there doesnt seem to be any place for it in there to sit on...
whats are some benefits of the three?
thanks guys
Old Dec 15, 2004 | 10:58 AM
Deceit's Avatar
Deceit
I've seen a few installs with amps in the passenger side glove box. Seems like a pretty nice place to mount your amps and you'll have the convienience of getting to them by opening the glovebox door
Old Dec 15, 2004 | 12:04 PM
crpav's Avatar
crpav
My amp is right behind the passenger side seat. A picture can be seen in my post a few down.
Old Dec 15, 2004 | 12:32 PM
Zenvy's Avatar
Zenvy
I have both of my amps behind the DRIVER'S side compartment where the OEM sub used to be...the installer made a shelf for the amps and it looks cool...only downside is that i won't get to see the amps again
He did this so that i could still use the glove box.
Old Dec 15, 2004 | 01:10 PM
dannichols's Avatar
dannichols
I put them in the compartment behind the driver's seat and used a flat piece of peg board to mount them to. I used a couple spot ties for secureness and on the underside I epoxied pieces of foam to keep the rear up high and stop it from rattling/bouncing around.
Old Dec 15, 2004 | 06:34 PM
rplink's Avatar
rplink
Not to difficult to make a platform from .5inch mdf. Use a couple of small spacer blocks on the bottom where needed to keep it level. Couple of L brackets on the left side to hold it in place and one support brace in the back to put tension down. That's all I did for my first install and it worked well.
Now that my amps are between the Hump and rear brace, I use the platform for all my crossovers.
Have a look.......
Old Dec 15, 2004 | 10:41 PM
530_350's Avatar
530_350
thanks alot guys
Old Dec 15, 2004 | 10:43 PM
530_350's Avatar
530_350
im just waiting for my box from nazar...i got a infinity kappa perfect 10Dvq, with a phoenix gold xenon 400x1 amp... cant wait for the install
Old Dec 16, 2004 | 05:20 AM
ousig's Avatar
ousig
Does any body still have their measurments for the drivers side compartment.
Old Dec 16, 2004 | 07:55 AM
bixby's Avatar
bixby
I did the same. I don't care if I see it again though. I like it "stealth".
Old Dec 17, 2004 | 12:01 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
I have a roadster...does anyone know what the stock bose sub compartment is like? Someone was telling me the rollbars go right thru there.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
