amp turns on/off during play
Old Dec 16, 2004 | 10:21 PM
tractng's Avatar
tractng
Default amp turns on/off during play
Guys,
My PG xenon 600.1 amp turns on/off randomly. I just noticed it today. This amp is about one week old. My 4 channel amp doesn't have this problem.
Anywhere I should troubleshoot first. I noticed it happen at all different volume (not just at high peak).
I have a 4 gauge coming to a block. From the block i have another 4 gauge going to the sub amp. Also, an 8 gauge going to my 4 channel amp.
When I first got the amp, I was anxious and installed it really late that night. Everything works.
Last weekend, when I had some time, I re-wired the whole thing and make it look nice and clean. Thats when the problem starts to occur (haha).
Btw, i have a 4 gauge wire for ground on the sub amp.
Tony
Old Dec 17, 2004 | 12:16 AM
OgreDave's Avatar
OgreDave
Loose cable somewhere? (power or ground) .. that'd be my initial guess from what you've said ..
Old Dec 17, 2004 | 11:22 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Overheating? It gets too hot and turns itself off to protect itself from burning up.
Old Dec 17, 2004 | 05:48 PM
OgreDave's Avatar
OgreDave
If he didn't move locations & it was fine before, I don't see why rewiring would cause it to overheat ..
Old Dec 17, 2004 | 06:10 PM
Santacruzslick
Veteran
Maybe some of your connections are shorting out when you go over bumps or something.
Old Dec 17, 2004 | 06:30 PM
Deceit's Avatar
Deceit
Sounds like a bad ground.
Make sure it's grounded to the chasis on a full metal point. Sometimes changing a ground can fix funky problems like that.
Good luck!
Shane
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
