rear fill power
Old Dec 17, 2004 | 02:31 PM
dannichols's Avatar
dannichols
Default rear fill power
Some of the component crossover sets (like Diamond Audio)feature outputs to run the rear-fill speakers using the power running to the front components. Has anyone tapped into these to power the rear 6.5's, or do you all use a 4-channel amp?
Old Dec 17, 2004 | 02:38 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
5 channel here...Diamonds in the front. Installer mentioned that I could do it but said it was crappy.
Old Dec 17, 2004 | 03:08 PM
dannichols's Avatar
dannichols
Yeah I can see how it would be best to power all speakers with sufficient power..but I use my fronts for 95% of the sound..with only 5% coming from the rears it seems like a waste to run a 4-channel amp. Seems more logical to just run them from the head unit speaker outs or the crossover pass-through.
Old Dec 17, 2004 | 03:23 PM
Santacruzslick
Veteran
But amps look pretty bad ***! :-)
Old Dec 17, 2004 | 03:27 PM
dannichols's Avatar
dannichols
Dude, mine are hiding in the cubby behind the driver seat. Are your's on display or something? What kind of Amps do you have?
Old Dec 17, 2004 | 07:55 PM
bastard's Avatar
bastard
You could run them off the rear outputs on your headunit. At low levels, it'll sound fine.
Old Dec 17, 2004 | 08:10 PM
LS350Z's Avatar
LS350Z
Charter Member #56
Definitely run them off their own power source. I personally hate rear fill (unless watching video) so I'd want the ability to fade the rears out for music.
