alpine d300
Old Dec 20, 2004 | 12:10 PM
zukbang's Avatar
zukbang
Default alpine d300
i have no VIDEO.
anyone here have this unit? i kinda know what is wrong right now. but i have a question.
if you do not park your car, you have no video unless you bypass with a switch,right?
my question to you is that, if you do not park you car, you have no access to your display setup?which means i can only control V.SEL and SEL. is this right?
right now, i have no video and i can not access iPersonal, DVD setup, etc... i can not even change time and brightness.
is this normal?is the car has to be in park to change these setup or is mine defected...just wanna know if you can access iPersonal and DVD setup menu while the car is moving with out bypass switches.
please someone help me.
thanks
Old Dec 20, 2004 | 03:31 PM
Geezzzz's Avatar
Geezzzz
Default Re: alpine d300
Originally posted by zukbang
i have no VIDEO.
thanks
I have this unit in my z. the car has to be in park with the emergency brake engaged in order to watch a movie and access ipersonal and dvd setup, etc . you should bypass with a switch. Actually, 2 switches. Alpine made it a little difficult to bypass with a single switch.
Old Dec 20, 2004 | 04:15 PM
zukbang's Avatar
zukbang
that's all i need to know.
thanks geezzzz.
without the bypass switch, you can not change the clock either,right?
Old Dec 20, 2004 | 06:07 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
You cannot get into any in-depth menus. You have to stop, the the weird a$$ combination with the brakes, and then fix everything. I hate that stupid brake combo. That's why I'm puttin in the bypass switch.
Old Dec 20, 2004 | 06:28 PM
Geezzzz's Avatar
Geezzzz
thanks geezzzz.
Right. the unit is operating correctly.
Old Dec 20, 2004 | 06:40 PM
zukbang's Avatar
zukbang
thanks guys..i guess i'll have to reinstall my unit with bypass.
btw, do you guys use any remote controls?
i can't seem to find a decent remote for our d300.
Old Dec 20, 2004 | 08:03 PM
ZNizzy's Avatar
ZNizzy
I have an Alpine and it is very easy to do once you've done it. I've had mine for over a year and takes me less than 5 seconds.
First-(without the unit in DVD mode and already car started)Press in and hold foot brake
Second-(still holding down foot brake) Press, and hold in, button on hand break
Third-(while holding in button on hand brake) Engage and disengage hand break 3 times(make brake light come on)
Fourth-After disengaging brake on 3rd time release button and let foot off the foot brake.
If you ar ever pulled over by police pulling the hand break a 4th time anytime after you have done this will put the screen back into a safety mode.
Old Dec 21, 2004 | 01:05 PM
Geezzzz's Avatar
Geezzzz
I used a push putton switch and a toggle switch to simulate the foot brake and the emergency brake. that way, the safety feature can be enabled and disable on the fly.
Old Dec 27, 2004 | 11:47 PM
gohandbz88's Avatar
gohandbz88
So does anyone have a how to write up on how to wire up this bypass?
dcains
Nov 11, 2015 11:36 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
Nazar
May 26, 2003 09:37 PM
toothlessracer
Mar 15, 2003 09:06 AM
dmcgibbo
Nov 30, 2002 10:11 AM
