I need advice on 10 in subs
Old Dec 22, 2004 | 06:32 PM
MCopare's Avatar
MCopare
Default I need advice on 10 in subs
alright...I am getting a box for under the brace in the back. Now the box is .75 cubic ft. I can put roughly a pound of polyfil to increase volume to 1.75. Anyone recommend any 10 inch subwoofer, with a mounting depth of no greater than 6.5 inches?
Old Dec 22, 2004 | 08:30 PM
rplink's Avatar
rplink
What amp will you use to power the sub? Watts/channel?
What do you want from the sub,,,,SPL, SQ, SQL?
How much do you want to spend?
Old Dec 23, 2004 | 02:25 AM
MCopare's Avatar
MCopare
no more than 200 each. SQ. 2 Channel in 2 ohm putting out 900 RMS.
Old Dec 23, 2004 | 08:21 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Diamond audio makes some good 10".
I just got a thin mount Diamond sub. Not installed yet but I've heard good things about it online.
Old Dec 23, 2004 | 09:21 AM
rplink's Avatar
rplink
Lots of good choices for you needs.....
For SQ, you can easily get by with a single 10" sub. Might want to consider the following:
RE SE 10
CDT Audio HD 1020
Adire Audio Koda 10
This is just a few examples of good SQ subs which you might consider. The Koda 10 is a Single Voice Coil Sub at 4 ohms, so it might not be the best match to the 2 channel amp you have.
The others are DVC and you could run each voice coil with it's own amp channel which will typically give superior results versus bridging the amplifier.
Alot of other good choices out there. Did you buy Mike's box off of eBay? I did and with a single Koda 10 and stuffing the box with "polyfill" it really sounds nice.
Good luck.
Old Dec 23, 2004 | 01:54 PM
MCopare's Avatar
MCopare
Yup gpt Mike's box for the two 10's. Thanks for the suggestions.
liqalu04
Jan 2, 2022 12:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
