Hardwired V-1, How do you tuck wires in Roadster
Old Feb 5, 2005 | 04:28 PM
zand02max's Avatar
zand02max
Default Hardwired V-1, How do you tuck wires in Roadster
Okay, I got my V-1 hardwired and I ran the phone cord wire up through the drivers side pillar, but I cannot get the wire to go under the roofline. How do you tuck the wire under the roof line. I tried to push it through with a screwdriver, but I am afraid of scratching my panels. I pushed really hard with a flat head and the panel would not budge. I have the roadster if that matters.
Any special tool for this?
Help,
Old Feb 6, 2005 | 10:17 AM
zand02max's Avatar
zand02max
Bump, anyone with a Roadster do this?
Old Feb 6, 2005 | 12:10 PM
GaryM05's Avatar
GaryM05
Does the roadster have a powered mirror like the coupe? If you can't find a solution to running the wires from the fusebox via the windshield frame, you might consider hardwiring straight to the mirror wires.
Good luck!
Old Feb 6, 2005 | 12:54 PM
zand02max's Avatar
zand02max
Good luck!
Yeah, looks like I will have to go that route, I really don't want too since its all wired, just needs to be tucked. I'll run it by a local stereo shop and see if they can tuck it without scratching anything.
Old Feb 8, 2005 | 07:29 AM
mgk65's Avatar
mgk65
Use something that is thin like a credit card to push the cord under the roofline.
Old Feb 8, 2005 | 12:37 PM
zand02max's Avatar
zand02max
Tried that, but it seems the roadster panels are much harder to push anything in, LOL!
Old Feb 11, 2005 | 03:56 PM
zand02max's Avatar
zand02max
Okay, I fixed it, it tucked on the left side, kinda weird, but hey whatever works,
Tapped into the front cigarette lighter. Saved $35 in the process by doing it myself.
Old Feb 12, 2005 | 07:31 AM
Speedracer's Avatar
Speedracer
I got my wire to fit on my roadster under the top windshield edge on the driver side but it is very tight. I used a plastic knife to not scratch the plastic. Make sure the wire is inserted under the plastic in its "flat" orientation. It definitely will not fit otherwise.
350Z_Al
Oct 29, 2020 07:44 PM
jlb
Oct 15, 2017 05:10 AM
nanotech
Oct 2, 2015 05:02 AM
416blueZ
Sep 25, 2015 10:00 AM
