350z base radio input question
Does anyone know if the base radio(not the Bose) on the Z has an aux in?
I have plug n play sattellite unit and would like to hardwire it to the Z's radio.
Thanks,
Thanks,
I believe it does, I also have a murano with bose and I added the pac aux in to it. When I took the HU out of my base Z, I noticed the same sat input on the back, I didn't bother testing it out since I was upgrading the HU, give it a try and let me know how it turns out!
Hep, that brown connector is the sat input, go get a pac aux adapter, it plugs into any nissan factory HU with sat in, again I didn't actually try it, but that brown input is for a satellite radio tuner.
The PAC will not work unless you have got SAT in. The CD Changer and SAT inputs look identical which is why both older and the latest head units have the same 12 pin connector.
For a non-SAT ready HU you need the Soundgate ALNS1 and Soundgate AUXCBLALP. The internal circuitry is different however.
As you can see they are pricey: Logjam link
It's meant to be selectable by pressing the CD button twice.
I don't have a Soundgate adaptor - check with them. I'm just trying to point you in the right direction.
Soundgate Link
Soundgate Link
bcoffee20
Nov 19, 2015 06:39 PM
