Screen in the navigation door
Originally Posted by bwoodballa
I cant find this monitor anywhere.It looks like the TME-M580 on alpines website, if you find where i can get one let me know!
Originally Posted by solidsnake
Also post pics of the 2 parts(cluster lid and finisher) I need to make sure that I have them..Thanks!
http://www.spintronic.com/gallery/35...eadunit_screen
One part is the whole lid/cubby hole assembly. You can't get that one wrong.
The other part in question is that gray, wide, sloped piece of plastic in front of the bottom of the screen. All it is is a cover/trim piece to hide the screws behind it.
Ok I have the alpine radio. Whats that one part I need for audio? Where can I get it and how much?
I did a quick search, and found these:http://www.millionbuy.com/accainetaux.html
http://www.millionbuy.com/accmbusaux.html
If you have an Alpine headunit that uses AInet, then you'll need the first link. If you have an Alpine that uses M-Bus, you need the second link. Once you plug in that adapter, you'll magically have 3 source options available instead of 2 when you hit the source button: Tuner -> CD -> Auxillary.
Note that this adapter uses the AInet/MBus port on the back of your head unit. This port is also used by CD changers. If you want to use the adapter *and* a cd changer, then I believe you can get a splitter of some sort to allow you to use multiple devices.
WHats that AI used for again? Do I really need it or.... I want to install all my stuff tomorrow and dont want to wait any longer..that one part on performance nissan thats like 10 bucks, which is that?
i also purchased an 03 Nav cubby to make my install easier. i bought a NESA 7 inch touch screen. It fits great! i have it installed in the cubby. here are pics of how i secured the screen to the cubby as well as the final product prior to install. i paid $199 with free shipping for the screen.
Originally Posted by jreiter
What device(s) do you have that support the touch screen capabilities?
screen fits like a champ. pics tommorrow of the completed install.
http://www.millionbuy.com/nesnstm7055.html
where do i get the cables long enough to reach from the ps2 to the screen? gamestore?
pics of my completed install
i'll take better pics this weekend.
the inverter is double-sided taped and zip-tied to a what i'll call for now a beam between the passenger side glove box and the stock sub location. pics would help out a lot in explaining the position of the inverter but i have none at this time. it is raining outside right now or i'd take a pic for you. i'll try to get you one tomorrow. the inverter i bought at circuit city. the wires/cable actually, came with the PS2. the cable reached from the head unit to the PS2 with no problems.
VitaminZ's PS2 location is the same as mine. Sorry about the large image size. That's all I've got hosted on my site:
My inverter is simply tucked away underneath that tray that the PS2 is on.
