Screen in the navigation door
Old Mar 29, 2005 | 05:26 PM
jreiter's Avatar
jreiter
Originally Posted by Th3Cleaner
How much bigger is this NON navi compartment vs the 2004/05 model?
My 2004 is extremly small, I dont see how a screen will fit even cutting the plastic up.
thx
That was exactly the problem. The '04+ models have a whole different assembly. The '04 door hinge support mechanism goes down the sides, so you can't trim much plastic away from the sides before you hit that. On the '03 assembly, though, the door slides up into the top, so the entire door support mechanism is on *top* of the box. This means the sides are completely unblocked.
Also, like I mentioned earlier, the '03 assembly pocket is a separate piece from the door. So, it just unbolts and you can remove it, leaving you with a big hole where the pocket used to be. The '04 assembly is all one piece, requiring you to cut it away. That's just a pain, and it doesn't result in anywhere near as much useable space as an '03 gives you.
Old Mar 30, 2005 | 05:36 AM
bknezevic's Avatar
bknezevic
I'm not sure of how they improved the '04.5+ interior over the '03 and early '04 models, but is the door and trim the same material as the '05? It's got that like gridded meshy looking type texture on the entire dash and doors, etc.
I wouldn't want to change out the whole nav compartment assembly if it will look mismatched with the current interior.
Also, isn't the nav door in the '03s like clunky and has a problem with something. I can't remember, but I do recall reading something about it.
Overall, do you think its worth the effort?
Old Mar 30, 2005 | 06:41 AM
Th3Cleaner's Avatar
Th3Cleaner
Thank you for this insite, It was what I was after!
I am ordering the 03 parts (2 pcs) right now from Performance NIssan dot com. they sell it for 75.00 and the dealership sells it for 130.00
Thank You
Old Mar 30, 2005 | 06:20 PM
z scag z's Avatar
z scag z
subscribing cause im planning on doing a mod like this in the near future
Old Mar 30, 2005 | 06:52 PM
d21arren's Avatar
d21arren
where did you guys buy your ferenheit screens from?
Old Mar 30, 2005 | 07:42 PM
Th3Cleaner's Avatar
Th3Cleaner
I purchased the Dynamix from their web site, they were extremly fast when shipping, and great people their too (called them on sizes and numbers). The screen I picked up was 275.00 it looks awsome, it has VGA, video 1 and 2- so 3 applications can be ran through it, just a great picture, package, price etc.. I could'nt be happier. played xbox through it at work for a couple hours, then watched 2 movies, took it home and plugged it in to my server
I also purchased the 03 cubby from performance nissan and they packaged it and shipped it an hour after I called them... cudos A++
Old Apr 14, 2005 | 06:41 AM
gburch's Avatar
gburch
PerformanceNissan.com is quoting me around 120 for both peices before shipping. How did you guys get the $75 + $9 Deal? The compartment alone was quoted at $109.
Old Apr 14, 2005 | 01:12 PM
z scag z's Avatar
z scag z
Im trying to do this same mod but i need some help
if any of you get a chance can you check out my thread and help me
https://my350z.com/forum/audio-and-video/117985-planning-to-build-a-little-system-for-my-car-this-summer-but-i-need-help-plz.html
Old Apr 14, 2005 | 02:54 PM
jreiter's Avatar
jreiter
Hmm... weird. Maybe prices got raised recently? Or maybe they aren't giving you the my350z member discount? Or maybe it's just a new person working there who doesn't know the rules yet.
Old Apr 15, 2005 | 06:50 AM
bknezevic's Avatar
bknezevic
I asked this question before, but didn't get a reply.
If you do the '05 to '03 nav compartment swap, is there a difference between the type of dashboard material between the two?
I know they updated the '04.5 and up with different interiors, but I just wanted to make sure if I did the swap (which I really want to do badly) then will it look dumb and mismatched??
TIA
Old Apr 15, 2005 | 07:27 AM
DougJones's Avatar
DougJones
The textures are very similiar. However, the colors are not. The '03 has more of a gray color as opposed to black in the later models.
Old Apr 15, 2005 | 04:48 PM
jreiter's Avatar
jreiter
Yeah, the 03 door seems to be a little lighter in color than my 04 dash.
Old Apr 15, 2005 | 09:48 PM
solidsnake's Avatar
solidsnake
OK I ordered the part from a member..I thought I needed 2 pieces.. HELP!!. Also I want to hook up my PS2 to the screen. How do I, what do I need to buy and where to put it?
Old Apr 17, 2005 | 01:18 AM
jreiter's Avatar
jreiter
Yes, I already posted the two parts you need in my 2nd post in this thread. Once again, they are:
OEM Cluster Lid 2003 350Z Non-Nav (68250CD010)
OEM Finisher for Cluster Lid 2003 350Z (68410CD000)
As far hooking up your PS2, most screens will have a standard composite video input. Easy. Hooking up sound is another matter, and will be completely dependent on your head unit. My Alpine headunit has an auxilary audio input which I used for my PS2. However, on Alpine headunits you have to get the AInet audio input adapter to make that work. It's a relatively cheap part you can find at any Alpine dealer, but you have to have it nonetheless. Other brands of headunits will differ. If your headunit doesn't have an aux input, you'll have to use one of those FM modulators that transmit the PS2's sound via FM, and you tune it in via your radio. Those are also very common. Your local car audio shop should probably stock some of those, or they can be found on the net at most good car audio retail sites.
As far as where to put your PS2... c'mon man, you have to decide on some of this yourself. There are lots of places you can stash it. It's up to you. (Hint: Many people use the big storage box behind the passenger seat since it has so much room.)
Old Apr 17, 2005 | 08:02 PM
bwoodballa's Avatar
bwoodballa
I cant find this monitor anywhere.It looks like the TME-M580 on alpines website, if you find where i can get one let me know!
Old Apr 17, 2005 | 09:02 PM
absoluturq's Avatar
absoluturq
Default hello
please delete this
Old Apr 17, 2005 | 11:41 PM
solidsnake's Avatar
solidsnake
Ok I have the alpine radio. Whats that one part I need for audio? Where can I get it and how much? Oh and I have the farenheit 7001. Anyone post pics or an how to on installing? Also, any posts on removing the dash?
Old Apr 17, 2005 | 11:46 PM
  #38
solidsnake's Avatar
solidsnake
Also post pics of the 2 parts(cluster lid and finisher) I need to make sure that I have them..Thanks!
Old Apr 18, 2005 | 12:26 PM
  #39
lascala26's Avatar
lascala26
Just a FYI.....PSP doesn't fit too well in 2003s. I just tried it. I need to fabricate sometype of support if I want to use it in the nav. box.
Old Apr 18, 2005 | 03:28 PM
  #40
BPL's Avatar
BPL
Here are some more screens...
http://www.mp3car.com/store/index.php?cPath=25
I have the Lilliput 7" installed and it fit perfectly.
