replacing factory sub
Old May 27, 2005 | 11:14 AM
gerthiekins's Avatar
gerthiekins
Default replacing factory sub
Does anyone know if there is a way that you can just replace the factory sub with just an aftermarket sub and if it would be worth it, i would prolly dynomat the inside all to hell to insulate it some, i am not sure if this woudl even work or not, woudl i be able to do this and if so would it be worth it i don't want a huge kick in bass but i want something a little more than the bose?
Old May 27, 2005 | 11:27 AM
jkoc's Avatar
jkoc
do a search for "basslink" in this forum looks like we have the same goals for audio..
Old Jun 23, 2005 | 02:50 PM
VO...'s Avatar
VO...
Administrator
You will have impedence mismatching problems. The Bose speaker system has a wierd impedence load, not like your typical speaker load of 2ohm, 4ohm, or 8ohms. The amp will not funciton properly is an impedence mismatch occurrs and it is no stable @ that particular load.
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
