Questions about NAV in the roadster
Where is the GPS antenna located in a roadster with factory NAV?
Anyone install an aftermarket NAV system in the roadster?
Could I put an aftermarket GPS antenna inside the car on the roadster since is has a soft top? Will the signal pass through the soft top? It seems like it should since it does have to penetrate the plastic housing of the GPS antenna itself.
