Antenna Amp Wire
Old Jun 17, 2005 | 07:53 AM
Bluebke's Avatar
Bluebke
Default Antenna Amp Wire
Hey I am just relaizing that the reason my reception sucks is because I have to power the Antenna amp. Can anyone tell me which wire that goes into the headunit is for powering the antenna amp so I can power it for my aftermarket stereo? I have an Alpine 9855 with no reception when I am in any kind of mountainous region which is pretty much everywhere.
Thank you very much
Brett
Old Jun 17, 2005 | 08:00 AM
DougJones's Avatar
DougJones
The blue wire on your Alpine harness is for the power antenna. I believe that the corresponding wire on your vehicle wiring harness is blue as well.
Old Jun 21, 2005 | 03:18 PM
VO...'s Avatar
VO...
Administrator
I have the same problem and wondered if the antenna had a pwr booster. Someone form soundomain told me that the 2003 does not have an antenna booster. My reception still sux.
Old Jun 21, 2005 | 05:20 PM
Art Vandaleigh's Avatar
Art Vandaleigh
Yes it is the blue wire, i had the same problem until i looked and saw i forgot to connect it.
Old Jun 22, 2005 | 07:06 AM
VO...'s Avatar
VO...
Administrator
So then it is the blue wire on the harness? If so, does this wire power up the antenna booster via the Bose amp? I removed the Bose amp completely. If the antenna booster is powered, via the amp, then I'm hosed.
Old Jun 22, 2005 | 08:25 AM
jkoc's Avatar
jkoc
i dunno what diagram you guys are referrring to when you say "BLUE" wire....
the ANTENNA BOOSTER AMP WIRE which MUST be connected in order to get decent FM/AM signal, is kind of a separate single wire bundled with foam along-side the main thick antenna lead. its got its own (brown?) connector as per the manual on page AV-31. the wire colour is typically GREEN/WHITE. my car (2003) it was green/white wire as per the manual.
i had to cut this and discard the brown connector and connect it to the new HU's antenna power wire (using solder, butt connector, or whatever you prefer). on my sony hu, this is powered 12v only when i select the source as radio tuner; otherwise it is off. this works out perfect with the antenna booster wire on the Z. if you dont have a power antenna lead in your HU, maybe try a REMOTE-AMP lead on your hu? if you do this, you'll probably have the antenna booster amp on all the time -- and you lose the capability to power-on any future external amp in sync with your HU...
Old Jun 22, 2005 | 08:27 AM
jkoc's Avatar
jkoc
see attached image of diagram from manual
Old Jun 22, 2005 | 09:37 AM
DougJones's Avatar
DougJones
It is not that complicated. If you have an aftermarket wiring harness for your vehicle, the blue lead on that harness needs to be connected the the power antenna lead on your Alpine. Both of these wires are blue. The other blue wire on the Alpine harness (actually blue w/white strip), is your amp remote turn on lead.
Connect the blue wires and enjoy great radio reception.
Old Jun 22, 2005 | 10:42 AM
westpak's Avatar
westpak
SFZCC
2003's do have the booster, I had no reception when I installed my aftermarket headunit and left the blue wire on the harness disconnected thinking it was for a power antenna, I recently installed an amp and found out about the wire and connected it and now have reception.
Old Jun 22, 2005 | 11:03 AM
VO...'s Avatar
VO...
Administrator
Now that I recall installing my aftermarket HU, I do remember that little wire off to the side. I had foam around it and I couldn't figure out what it was for, so I left it alone. Man, it is going to be a pain to remove that HU again. Gotta do what I have to do. Thanks guys.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
