kenwood dv4100 nav install?
Old Jun 22, 2005 | 04:42 PM
onii's Avatar
onii
Default kenwood dv4100 nav install?
anyone know how hard the install is for the dv4100? i'm hooking it up to a ddx7015. i saw a lot of wires in the picture, so not sure if it'll be a ***** to hook up. lemme know!
Old Jun 24, 2005 | 04:08 PM
Shift_Daytona Z's Avatar
Shift_Daytona Z
I know how, I need pics of your wires though
Old Jun 24, 2005 | 07:37 PM
THEDUKE's Avatar
THEDUKE
The navigation plugs directly into the DDX7015 using a data cable. That is all you need to connect the Navigation to it. The navigation has its own set of wires that have to be connected. Most of them are as simple as hooking up a radio, Yellow=Constant. Red=Ignition. Black=Ground. All of these wires can be found on the radio harness. The other two wires that are different are the back-up light wire, which goes hooked up to the back up light wire(this wire is not really needed, the navigation will function correctly without it. The last wire is the white wire and is where everyone has trouble. It goes hooked up to the vehicle VSS wire. That is all there is to it. I forgot the antenna which just plugs into the unit.
Old Jun 29, 2005 | 02:56 PM
Shift_Daytona Z
Thank you there einstein you just read the instruction manual. Like I said give me a pic of the wires and I will tell you where the reverse wire is and the vss wire is to plug into.
Old Jun 30, 2005 | 12:38 PM
onii's Avatar
onii
for people with the nav...did u install the brain in the slot behind the driver seat? frmo the photos it seems the wires are not that long...how did u extend to the HU?
Old Jun 30, 2005 | 04:08 PM
THEDUKE's Avatar
THEDUKE
Sorry Mr.Einstein, I did not read the manual. I happen to know this because I work for Kenwood, not because I read the manual. As a matter of fact here is the VSS wire without needing pics. It is a white wire pin#26 at the unified meter and A/C amp which is located behind the A/C controls in the center console.
Old Jul 1, 2005 | 10:01 AM
onii's Avatar
onii
sooo...mr kenwood, how do i run the wires? ^_^
Old Jul 3, 2005 | 07:58 AM
The Liu Man's Avatar
The Liu Man
Yup, I installed mine in the cubby behind the driver seat. Still had enough space to close the cubby. Perfect stealth install. The people who did the install ran the wires through the center console I think. It's long enough.
Old Jul 3, 2005 | 12:00 PM
onii's Avatar
onii
yeah...i instlaled the HU earlier today. after doin that with my friend dave@active i feel fine bout doin the nav install. the Z comes right apart like a model car ^_^
Old Jul 3, 2005 | 12:51 PM
jazz z1's Avatar
jazz z1
Question for THEDUKE and The LIU MAN : How do you guys like the NAV? I'm comtemplating doing the same install. The best price I've gotton thus far is around $750. Is that a good number?
Old Jul 9, 2005 | 03:50 PM
Shift_Daytona Z
ummm you still had a stupid answer duke, anyways I do like the nav with the voice activation. I ran all of the wires through the center console and mounted it in the pocket behind the drivers seat. It is very clean and easy to do. Just pay close attention to the speed sensor wire. DO NOT SHORTEN THE WIRE. Just tie it up and tuck it somewhere.
Old Jul 10, 2005 | 02:04 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Hey can you post a pic of the unit mounted in the rear please? I want to see how it is mounted and if it is in the mailslot. Mine is mounted there but I am not crazy about the fabricated bezel that keeps falling off.
dcains
Nov 11, 2015 11:36 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
