? how to wire 300/2 to 10w3d2?
Old Jul 28, 2005 | 03:04 PM
onii's Avatar
onii
Default ? how to wire 300/2 to 10w3d2?
i have jl 300/2 amp, and i wanna wire it to jl 10w3v2, dual (2 sets of terminals)
i am not sure how to do the wiring to the sub itself. there are two sets of +- conenctors. do i run a + on one and a - from the other to the amp? do i need to also connect the remaining two to each other? someone let me know!
Old Jul 28, 2005 | 05:15 PM
momo 350z's Avatar
momo 350z
your sub didnt come with any wiring directions or diagram? anyways do you plan on bridging the amp or just running it off of one channel? to wire up the sub...connect one + wire to the - side on the speaker.then connect the other + terminal to the amp along with the - side..hope this helps
Old Jul 28, 2005 | 07:20 PM
onii's Avatar
onii
so... on the sub -+.............-+ like that?
+ on one side to the - on the other, then the remaining two to the amp?
Old Aug 1, 2005 | 09:51 PM
CKY4800's Avatar
CKY4800
Old Aug 2, 2005 | 10:31 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
(CKY4800 added the diagram while I was typing )
Look at page TWO of the JL 10W3V2 manual s the lower half of the page at the pictures. Take the SECOND row down which shows two subwoofers connecting to ONE amplifer. I'll assume that you're bridging the 300/2 amplifer to mono (there's a switch on it labled "bridging mode"). The 300/2 is rated down to 1.5 ohms so any of the right hand column configurations would work - choose the 2 ohm or the first one on the left hand column to give you 1.5 ohm.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
