Help!! Where are the screws that hold the cubby?
Old Aug 9, 2005 | 05:11 PM
AZ350Z's Avatar
AZ350Z
Default Help!! Where are the screws that hold the cubby?
I searched and read all threads and cannot figure out how to get the plastic cubby out of the dash. All I found so far are the two screws under the rubber mat inside the cubby.
How do I get the whole thing out so I can install the Faranheit from behind?
It's a 2003 cubby in a 2003 car btw.
Thanks.
Old Aug 9, 2005 | 05:25 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You need to start behind the shifter and work your way forward.
The ring around the shifter comes off. Just pulls up on the auto.
Then the plate that contains the AC controls - pull up from the crack exposed by the shifter's ring.
Disconnect the white ribbon cable.
There's two screws on either side of the white box behind where the AC controls were.
I think that's it ... ?
Old Aug 9, 2005 | 05:29 PM
AZ350Z's Avatar
AZ350Z
thank you. I didnt know i had to take all that off.
Old Aug 9, 2005 | 06:57 PM
AZ350Z's Avatar
AZ350Z
OK, 1 more question. I got all the job done except for the red and black wire coming from the farenheit. Anywhere in particular those should be connected?
Old Aug 9, 2005 | 07:06 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The screen's red wire connects to the ignition controlled ACC wire. That ought to be a blue with green stripe wire running to the back of the radio. The screen's black wire is grounded.
Old Aug 9, 2005 | 07:08 PM
AZ350Z's Avatar
AZ350Z
Thank you very much.
Juztin
Nov 22, 2015 07:03 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
