OEM WOOFER for 350z - Pls help
Old Aug 25, 2005 | 05:08 PM
04350zTouring's Avatar
04350zTouring
Exclamation OEM WOOFER for 350z - Pls help
Where can I get a Original Woofer setup for the 350z? I would like to add one to my car, but don't want to sacrifice space of the trunk, as I am a golfer and need to put my clubs in the trunk too.
i saw a picture in this forum where the woofer sits in the corner of the trunk. My car comes with the BOSE system, but apparently, according with the dealer, it does not have a woofer. I have not seen the car, only pictures from their website.
Anyone can help me out?
Thanks,
Dennis (04350zTouring)
Old Aug 25, 2005 | 05:20 PM
dannichols's Avatar
dannichols
The Bose system has a woofer behind the driver's seat.
Old Aug 25, 2005 | 05:51 PM
04350zTouring
In all year and model?
I have a 2004 350z Touring
if I change just head unit will BOSE WORK? is it decent sound you know?
Thanks.
Old Aug 25, 2005 | 08:02 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The Bose woofer blows.
This is a un-retouched photograph showing the Bose next to a mid-price mid-quality Infinity woofer. That big thing sitting between them is part of the Infinity - not the missing magnet from the Bose!
I would rather see you buy the frame and speaker grill and mount an aftermarket "free air" woofer in there. A normal woofer is meant to be hung inside a box. The trapped air inside the box acts as a spring to help control the woofer. A free air woofer has different mechnanical construction to allow it to work outside a box.
You should be able to buy a frame from someone here pretty cheap, the speaker grill on line or from your dealer, and the woofer from any good stereo shop on-line too.
Old Aug 25, 2005 | 09:58 PM
dannichols's Avatar
dannichols
Thanks.
Best way to tell is look behind your driver seat.. The cover of your cubby will either have a speaker grill that says Bose on it...or will be a big blank piece of plastic. Either way..my advice would be replace as much of it (Bose or not) as you can. The picture above should give you a very good idea of the quality of any stock 350z stereo equipment.
Dan
Old Aug 27, 2005 | 06:28 PM
MacRayZ's Avatar
MacRayZ
PM sent. Check inbox
Old Aug 27, 2005 | 07:39 PM
ZSUNSUN's Avatar
ZSUNSUN
Hey, check this website
Click
Z 2003~5
Interior and should be around mid way or so...
http://www.courtesyparts.com/
Old Aug 27, 2005 | 08:25 PM
Mantis3024's Avatar
Mantis3024
will that fit in the stock woofer location?
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
