door panel speaker grills
Old Aug 26, 2005 | 08:51 AM
350ZREDLINE's Avatar
350ZREDLINE
Default door panel speaker grills
was wondering has anyone done anything wtih the speaker grills in the doors since they only have about half of the holes cut out?
I was thinking of cutting the rest of the holes out but then i thought to myself that it might look weird and what if i mess up. Is there any other solution (besides leaving them off?)
i figured with only half the wholes cut out that it would affect sound quality... I dont know why nissan did this (maybe to hide the bad sound quality of the stock system? ? ? :P)
Thanks for any help or ideas about it. Im sure some of you have done something with the factory stock speaker grills in the doors.
Old Aug 26, 2005 | 10:02 AM
dannichols's Avatar
dannichols
Many people here have used a dremel to route them out. I bought a special bit about 1/16" if I remember right to do it. Will not look perfect but better than stock.
I leave mine off.
Old Aug 26, 2005 | 10:04 AM
bixby's Avatar
bixby
Yep. Drill out the "fake" holes. I can't believe Nissan did that. But since the factory unit sounds like crap I guess it didn't matter.
Old Aug 26, 2005 | 10:10 AM
dannichols's Avatar
dannichols
The fake holes are actually a Nissan "Feature", so you can't here just how crappy the stock system sounds :-0
Old Aug 26, 2005 | 12:41 PM
THEDUKE's Avatar
THEDUKE
I cut the entire center section out. I was left with about a 3/4 inch frame of the grill all the way around, so it still kept the shape of the grill and the mounting clips. All I did after that, was cover it in black grill cloth and it looks stock. I will post pics tonight. Just so you get a ideal the entire center section of the grill is gone, but it looks like one piece when it is covered with the grill cloth.
Old Aug 26, 2005 | 12:45 PM
dannichols's Avatar
dannichols
EXCELLENT IDEA DUKE! I thought about doing that but was worried that the grill cloth would not conform to the weird curviture of the remaining grill. Post a pic please!!!
Old Aug 26, 2005 | 01:25 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
Well, the reason all the holes aren't cut out is because the speaker is so low in the cut-out anyway. All the holes in front of the speaker go all the way through.
Old Aug 26, 2005 | 01:36 PM
dannichols's Avatar
dannichols
With MDF spacer you can offset/raise the speaker 1" up and a bit back to better align with the hole. This is why I like Duke's idea..because otherwise I ride around with no covers.
Old Aug 26, 2005 | 04:07 PM
350ZREDLINE
were can u buy black grill cloth................ I assume a car audio place would have it? Or could u find it at a chain like best buy or something?
Old Aug 26, 2005 | 06:08 PM
THEDUKE's Avatar
THEDUKE
Here are the pictures with the grill on and off. I also took a picture of the back of the grill so you can see what was cut out.
Old Aug 26, 2005 | 06:24 PM
mysunset's Avatar
mysunset
they look great. NICE JOB!
Old Aug 26, 2005 | 07:20 PM
dannichols's Avatar
dannichols
Nice job. Cool use of the BA logo too.
Old Aug 26, 2005 | 08:31 PM
neur0sis's Avatar
neur0sis
did you just use spray adhesive on the grillcloth? I thought about this but was worried about how to attach the cloth to the frame of the speaker cover without making a mess.
Looks awesome!
Old Aug 26, 2005 | 08:55 PM
THEDUKE's Avatar
THEDUKE
Yes, All I used was spray adhesive. Also make sure when you put the cloth on you strech it or else it will have wrinkles in it.
Old Aug 26, 2005 | 09:22 PM
dannichols's Avatar
dannichols
I've never had good luck with the spray adhesives..even 3M #90. Maybe it's the heat around here but it never seems to stick for long.
Old Aug 27, 2005 | 12:12 AM
TiPIACE's Avatar
TiPIACE
my install is being built atm, and i had the installer drill out the holes as well
he spent a good hour on both despite telling me it was going to be a waste of time. It wasnt until i went down to the shop that i saw he was right. The covered portion of the speaker grille doesnt sit directly in front of the speaker anyway. If u look in the pics Duke posted, the speaker sits low down in the door where there are holes in the speaker grille
Old Aug 27, 2005 | 12:39 AM
dannichols's Avatar
dannichols
Make your own spacer, out of MDF and offset the hole 1" higher and back so it is in the center. Then the holes will make a difference. At least they did for me.
Old Aug 29, 2005 | 04:46 PM
350ZREDLINE
i did what the THEDUKE did (maybe not quite as good and it sounds ALOT better. Id recommend anyone with a aftermarket system to do this (or take out the grill altogehter)
Old Aug 29, 2005 | 07:01 PM
THEDUKE's Avatar
THEDUKE
What happened? Why do you think they did not come out right. I may be able to help you. The great thing is you can always take off the grill cloth and redo them. If you feel the cutting out of the grill was not to good, you can always buy a new set. They are only $12.00 each grill. I used a good blade to do the cutting of the grill.
Old Aug 29, 2005 | 07:12 PM
dannichols's Avatar
dannichols
Redline, please explain, I'm about to do the same thing. What is difficult about this? Where is it easy to mess up?
