Rear speakers don't work after HeadUnit replacement
Anyone had a problem with stock / base rear speakers after replacing the HeadUnit ?
I've replaced my stock base headunit with fosgate from Xterra and now rears wont work.. any ideas ?
rear fill sounds like a turd.
Originally Posted by Paul350Z
16 ohms shouldn't be a problem - you've got the wires disconnected somewhere.
any quick way of checking where it could be disconnected ? what are the connection points ?
Rockford unit you are using form the Xterra, Is that aftermarket ? If it is OEM it may not have any rear outputs. It may be designed to work with a factory amp in rear.
it is oem .. it just plugged in and that's it .. i dont think i had anything disconnected - cause those were oem plugs they just snapped in the back of head unit perfectly. also the rockford fosgfate is blinking at night.. i dont know what to do ... any help ?
If you can install it back in the Xterra and see what happens.
I bought this headunit on ebay.. the guy swears by it and says it was removed because he installed navigation system..so the headunit is supposed to be new and working .. i dont know if xterra has an amp or not.. how can i use the 350z's Amp with this unit ?
yup .. i had two harnesses that i plugged in.. basicly the fosgate came with 4 holes - and as far as i remember only two were usable for the harnesses that i had... f@#K i really dont want to remove the whole dash again..
and the weird thing is the light on the display lights up fine.. but the light on button and on volume / seek ***** - is always either half way light up or is blinking .. its very weird.. dammmit...
It is very possible that the OEM factory radio made by Fosgate is set up where the head unit powers the front speakers and the rear speakers are powered by an external amp, so the rear outputs or the Xterra headunit is only sending out a low level signal.
